Triple Z G28/G32 homing error
I'm having trouble setting up my printer to do auto bed levelling. It is a custom corexy machine using 3 individual Z motors and a bltouch as Zprobe.I can run M28 X, M28 Y and M28 Z individually without a problem.
M28 however throws: ''Error: Failed to enable endstops''bed.g
G28 ; home G30 P0 X0 Y0 Z-99999 ; probe near a leadscrew front left G30 P1 X369 Y0 Z-99999 ; probe near a leadscrew front right G30 P2 X177 Y329 Z-99999 S3 ; probe near a leadscrew rear mid. and calibrate 3 motors Also I can run:
individually, and it does work as intended
G32 however also throws: ''Error: Failed to enable endstops''
I assume because my bed.g starts with G28config.g
; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CryXY" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; X physical drive 0 goes reverse M569 P1 S1 ; Y physical drive 1 goes forwards M569 P7 S0 ; Z physical drive 7 = E4-RampsZ goes reverse M569 P8 S1 ; Z physical drive 8 = E5-RampsY goes forwards M569 P9 S0 ; Z physical drive 9 = E6-RampsX goes reverse M569 P3 S1 ; E physical drive 3 goes forwards M584 X0 Y1 Z7:8:9 E3 ; set drive mapping (changed to triple Zyx) M671 X201.5:444.5:-41.5 Y400.3:-20.6:-20.6 S6 ; level points from CAD at rear mid z, front right y, rear front left x. Snnn max correction move. Fnnn Fudge Factor M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm M566 X900.00 Y900.00 Z900.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z200.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-18 Y-3 Z0 S1 ; set axis minima (max travel X414 Y348 Z???) M208 X396 Y345 Z200 S0 ; set axis maxima (my current offset X-18 Y-3) ; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 R0.2 A3 ; set Z probe type to bltouch and the dive height + speeds MUA R A G31 P500 X24.5 Y4.35 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid DOOOOIT ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"BMG" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined Thanks
@Nordle what's in your homeall.g?
@jay_s_uk
homeall.gG91 ; relative positioning G1 H1 X-235 Z-205 F1800 ; move quickly to X or Z endstop and stop there (first pass) G1 H1 X-235 ; home X axis G1 H1 Z-205 ; home Z axis G1 X5 Z5 F6000 ; go back a few mm G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Z-205 ; then move slowly to Z axis endstop G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-215 F1800 ; move Y down stopping at the endstop G90 ; absolute positioning -
@jay_s_uk
I just remembered that when I first create files for this machine I selected by mistake coreXZ instead of coreXY in the configuration tool... I already changed that in config.g to corexy but didn't think of all the other files
could there be other corruptions?fixed my homeall.g to:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.14 on Tue Nov 15 2022 22:25:09 GMT+0100 (Central European Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-235 Y-215 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-235 ; home X axis G1 H1 Y-215 ; home Y axis G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-215 ; then move slowly to Y axis endstop G1 H1 Z-205 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning now G28 does work, but G32 still throws the error
Nevermind this, was wrong again, but you got me in the right direction. Thanks for that^^
@Nordle said in Triple Z G28/G32 homing error:
G1 H1 Z-205 F360 ; move Z down stopping at the endstopG90 ; absolute positioningG92 Z0 ; set Z position to axis minimum (you may want to adjust this)
This part needs to be replaced by a G1 X Y move to position the probe, and then G30 to use the probe to home z.
