    Scara Setup
    13.8k
    • DannyDefeundefined
      DannyDefe
      David
      I'm back after the show and would like to get this up and running. I have a complete installation on the big Scara now.
      All of the extruder speeds have been corrected but it essentially does the same thing. It homes perfectly at relatively high speeds without a problem. Then it starts to print and everything slows down, the distal arm just slowly comes in and crashes.
        links included the G-Code and a photo of the board installation.
      The prox switch is worked exceptionally well so if anyone else needs a 5 volt switch I would recommend these. We need the prox switch on the proximal base in order to do continuous rotation.
      [[url]https://www.dropbox.com/s/lp2tysdk2q5g7ff/20180326_170037.jpg?dl=0]
      [[url]https://www.dropbox.com/s/3sir48tk8nz2xfn/20180326_170049.jpg?dl=0]
      [[url]https://www.dropbox.com/s/35qs8g7ggpwc7dt/56 TEST.gcode?dl=0]
