    Duet3D wifi, not recognize SdCard
    • MrJundefined
      MrJ
      Hi Duet3D forum
      This April I bought a Duet3D board. Great Product - love it.
      On Wednesday I printed a little part ( maybe 1 hour print ).
      One day after I started the Printer and I could not connect with wifi.
      My first reaction was, connecting with USB and Pronterface.
      No problem, I can connect and the printer is online.
      I can move in Z.
      but when I send G28 it comes ->
      homing file
      homeall.g not found
      I checked the SdCard on my PC and everything was okay.
      What I tried
      3 various SD Cards - all the same problem
      Install new firmware -> comes Error 6
      Can someone help me, please?
      Thanks to all.
        Run M122 to get the diagnostic report. Under the Platform section, it will say whether the SD card was detected, and if so what the connection speed is.
        • MrJundefined
          MrJ
          Hi
          here the info when I send M122
          Connecting…
          ok T B:2000.0 /0.0
          Printer is now online.
          ok T B:2000.0 /0.0
          M122
          SENDING:M122
          Used output buffers: 1 of 32 (1 max)
          RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
          Board ID: 08DDM-9FAM2-LW4S8-6J9D4-3S46S-92Z7X
          Static ram used: 21176
          Dynamic ram used: 95528
          Recycled dynamic ram: 2080
          Stack ram used: 4048 current, 4872 maximum
          Never used ram: 7416
          Last reset 00:00:25 ago, cause: power up
          Last software reset reason: User, spinning module GCodes, available RAM 7996 bytes (slot 2)
          Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
          Error status: 0
          [ERROR] Error status: 0
          Free file entries: 10
          MCU temperature: min 27.4, current 31.1, max 31.2
          Supply voltage: min 0.0, current 0.6, max 0.7, under voltage events: 0, over voltage events: 0
          Driver 0: ok
          Driver 1: ok
          Driver 2: ok
          Driver 3: ok
          Driver 4: ok
          Slowest main loop (seconds): 0.000149; fastest: 0.000032
          MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: none
          Bed heater = 0, chamber heater = -1
          Segments left: 0
          Stack records: 0 allocated, 0 in use
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is ready with "M122" in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          Network state is disabled
          WiFi module is disabled
          HTTP sessions: 0 of 8
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            According to the M122 report it has initialised the SD card correctly. If you send M552 to the USB port, what does it report? Does M552 S1 respond a few seconds later with a successful connection message?
            Don't forget that the config.g cards on our standard SD card image have the M552 S1 command commented out with a semicolon character, and you need to remove that semicolon to have to connect to your router automatically.
            • MrJundefined
              MrJ
              Hi dc42
              With the M552 S1 I had started the duet3d Server but the settings were not there. Then I saw that the config.g was renamed to config.g.bak, I renamed it back to config.g and everything was good. But the thing now is, after a few restarts, it renamed again the config.go to config.g.bak and I must manual start the WIFI server.
                I suggest you move the SD card to a PC, check it for errors, then examine the config.g file and make any corrections needed. When you put it back in the Duet you must either restart the Duet or send M21 to tell it that the card contents have changed.
