    Ir Probe Error: M558: Missing Z probe pin name(s)
    RepRapFirmware on other controllers
    • Proschi3Dundefined
      Proschi3D
      I need help setting up the ir probe.
      I always get this error message: M558: Missing Z probe pin name(s)
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sat Nov 26 2022 13:27:47 GMT+0100 (Mitteleuropäische Normalzeit)
      M575 P1 S1 B57600                                         ; enable support for PanelDue
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      M550 P"My Printer"                                        ; set printer name
      M552 S1                                                   ; enable network
      M586 P0 S1                                                ; enable HTTP
      M586 P1 S0                                                ; disable FTP
      M586 P2 S0                                                ; disable Telnet
      M569 P0.0 S0                                              ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                              ; physical drive 0.1 goes forwards
      M569 P0.2 S0                                              ; physical drive 0.2 goes forwards
      M569 P0.3 S1                                              ; physical drive 0.3 goes forwards
      M569 P0.4 S1                                              ; physical drive 0.4 goes forwards
      M569 P0.5 S0                                              ; physical drive 0.5 goes forwards
      M584 X0.0 Y0.1 Z0.2 E3:4 U5                               ; set drive mapping
      M350 X256 U256 Y256 Z256 E256:256 I0                       ; configure microstepping without interpolation
      M92 X1280.00 U1280 Y1280.00 Z12800 E4632:4632      ; set steps per mm
      M566 X480 Y300 U480 Z24.00 E300.00:300         ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z180.00 E1200.00:1200.00         ; set maximum speeds (mm/min)
      M201 X900 U900 Y900 Z100 E3000:3000                       ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E400:400:400 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      M208 X-3 Y0 Z0 U35 S1                                          ; set axis minima
      M208 X327 Y240 Z240 U355 S0                                    ; set axis maxima
      M574 Z1 S2 P"io3.in"
      M574 Y1 S1 P"io1.in"
      M574 X1 S1 P"io2.in"
      M574 U2 S1 P"io4.in"                                       ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin null
      M558 P1 C"io3.in" H5 F120 T6000                           ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                       ; set Z probe trigger value, offset and trigger height
      M557 X15:305 Y15:225 S20                                  ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138              ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00                                          ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138              ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                        ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S340                                              ; set temperature limit for heater 1 to 340C
      M308 S2 P"temp2" Y"thermistor" T100000 B4138              ; configure sensor 2 as thermistor on pin temp2
      M950 H2 C"out2" T2                                        ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S340                                              ; set temperature limit for heater 2 to 340C
      M950 F0 C"out4" Q500                                      ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H-1                                            ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out6" Q500                                      ; create fan 1 on pin out6 and set its frequency
      M106 P1 S0 H-1                                            ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"vfd" Q500                                       ; create fan 2 on pin vfd and set its frequency
      M106 P2 S0 H-1                                            ; set fan 2 value. Thermostatic control is turned off
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Proschi3D
        @Proschi78 you can't use the same pin for 2 different things
        Proschi3Dundefined 1 Reply Last reply Reply Quote 0
          Proschi3D @jay_s_uk
          @jay_s_uk I have now deleted the second endstop, the result remains the same
          M201 X900 U900 Y900 Z300 E3000:3000                       ; set accelerations (mm/s^2)
          M574 Z2 S1 P"io6.in"                                       ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin null
          M563 P0 D0 H1 F0                                          ; define tool 0
            dc42 administrators @Proschi3D
            @Proschi78 said in Ir Probe Error: M558: Missing Z probe pin name(s):
            What command do you run that provokes that error message?
              jay_s_uk @Proschi3D
              @Proschi78 just an FYI, I wouldn't be running with x256 microsteps on your driver's. You'll be overstressing the MCU for no gain. You're better off with x16 with interpolation or x32 without
                Proschi3D @dc42
                @dc42 Thanks for the help I managed to do it
