    Having trouble setting the z offset
    6.2k
      @vhoward:
      The files were all created with the configurator. The homeall.g has never worked correctly and when I look at the file, it is greek to me. When I home all, it starts with the x axis and the x axis starts grinding and slowly moves away from the endstop. I have to either cut the power of press the emergency stop to get it to stop. However, I can home the machine by homing each axis separately.
      Please post your homing files.
      • vhowardundefined
        vhoward
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool on Thu Apr 27 2017 06:26:16 GMT-0700 (PDT)
        ; Relative positioning
        G91
        ; Lift Z
        G1 Z5 F6000
        ; Course home X or Y
        ;G1 X-305 Y-305 F1800 S1
        ; Course home X
        G1 X-305
        ; Course home Y
        G1 Y-305
        : Move away from the endstops
        G1 X5 Y5 F6000
        ; Fine home X
        G1 X-305 F360 S1
        ; Fine home Y
        G1 Y-305 S1
        ; Move Z down until the switch triggers
        G1 Z-285 F1800 S1
        ; Absolute positioning
        G90
        ; Tell the firmware where we are
        G92 Z2.5
        ; Uncomment the following line to lift the nozzle after probing
        ;G1 Z5 F100
        A little late, but here is my homeall.g file.
        • deckingmanundefined
          deckingman
          The G1 X-305 Y-305 … is commented out so you need to remove the semi colon from the beginning of that line.
          The next lines G1 X-305 and G1 Y-305 (course homing X and Y) don't have an S1 parameters so they will ignore the end stop switch. They should be G1 X-305 S1 and G1 Y-305 S1
          The bed is being probed at the X0 Y0 position for the Z axis and while it will work, it's generally better to probe the centre of the bed
          for Z home so you might want to add something like G1 X150 Y150 F6000 before the G1 Z-285 move.
          • vhowardundefined
            vhoward
            Thanks. Still learning the g-code world. Didn't even notice the first line was commented out.
              deckingman
              @vhoward:
              No worries. Read and inwardly digest this and you'll become an expert https://duet3d.com/wiki/G-code. 🙂 Alternatively bookmark it for easy reference in the future.
              • vhowardundefined
                vhoward
                My home all is now working like it is supposed to. And my z offset is working.
