ERROR update firmware
Firmware installation
  • undefined
    paolozampini1973
    Hello Can anyone help me when I go to update via YAT or DWC it gives me the error that the file is too big I tried all the versions what should I do Thanks
    108ab369-ddcf-4f54-955e-4a0f756b725c-image.png console.txt
    undefined 1 Reply Last reply 30 Nov 2022, 11:49 Reply Quote 0
    • undefined
      dc42 administrators @paolozampini1973
      @paolozampini1973 what is the size of that file, and where did you get it from?
      undefined 1 Reply Last reply 30 Nov 2022, 12:00 Reply Quote 0
      • undefined
        paolozampini1973 @dc42
        @dc42 https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.0
        Duet2and3Firmware-3.1.0.zip
        undefined 1 Reply Last reply 30 Nov 2022, 12:30 Reply Quote 0
        • undefined
          droftarts administrators @paolozampini1973
          @paolozampini1973 You are running RRF 2.05.1. To update to the latest RRF 3, you need to install RRF 3.0 first; later RRF 3+ files are too large. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#updating-without-firmware-erase
          Upgrading ANY Duet 2 from 2.x to 3.0 or later requires installing 3.0 first.
          The version 3.01 and later binaries are too large to be installed by the IAP program supported by version 1.x and 2.x firmware. Therefore you cannot upgrade directly from version 1.x or 2.x firmware to 3.01 or later firmware. This is the procedure:
          • Download file Duet2and3Firmware-3.0.zip from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
          • Upload and install that file on the Duet through Duet Web Control
          • Send M115 and check the response to confirm that you are running version 3.0 firmware
          • You can then upgrade to version 3.01 or later firmware.
          undefined 2 Replies Last reply 30 Nov 2022, 13:03 Reply Quote 0
          • undefined
            paolozampini1973 @droftarts
            @droftarts Yes I was aware that the update must be done progressively up to version 3.0 but I had already tried it before and it didn't work I did it again now and it worked I don't know why but anyway thanks you are always very very helpful Thanks very kind
            • undefined
              @droftarts what I'm building now then to build a lathe mill a machine that you can TONIRE and also has a milling cutter what I was wondering is that the Spindle How should the Spindle be configured Sara with a nema 23 ho 34 motor that spins a Spindle k12 -125 Connected with the belt
              undefined 1 Reply Last reply 30 Nov 2022, 19:13 Reply Quote 0
              • undefined
                Phaedrux Moderator @paolozampini1973
                @paolozampini1973 said in ERROR update firmware:
                Best to create a new thread with your question in the CNC forum.
                3 out of 7
