    Connected but can't get into web interface.
    Duet Web Control
    • Ottobawtundefined
      Ottobawt
      I've had a pair of these duet2's running most of the year without any major connection issues, but this week they just wont play nice with the web interface. They will "Wifi Module is connected to access point" but can't get into it with a web browser; it might connect for a few mins but then get booted off for indefinite/ever.
      I have two firmwares between the two of them, 3.4.1 and 3.1.1, both behaving identically on this note.
      I've played with my network things quite a bit, and can't get an improvement.
      A family member is wifi gadget obsessed, I don't know if they polluted the pool in the last week by adding yet another "smart bulb" on it, but nothing I've done has changed on the network, they printers just became more and more fragile to stay connected to this point.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1rc1 (2022-05-03 09:34:00) running on Duet WiFi 1.02 or later
      Board ID: 08DAM-9K9K2-NGNSN-6J9D6-3S46N-TPS3J
      Used output buffers: 3 of 26 (23 max)
      Static ram: 23868
      Dynamic ram: 74424 of which 24 recycled
      Never used RAM 10572, free system stack 102 words
      Tasks: NETWORK(ready,13.5%,200) HEAT(notifyWait,0.1%,321) Move(notifyWait,3.5%,295) MAIN(running,82.8%,421) IDLE(ready,0.2%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:27:19 ago, cause: power up
      Last software reset at 2022-11-22 18:55, reason: User, GCodes spinning, available RAM 13644, slot 2
      Error status: 0x10
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 33.1, current 49.4, max 50.5
      Supply voltage: min 23.7, current 23.8, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/66/22, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: ok, SG min 0
      Driver 1: ok, SG min 0
      Driver 2: ok, SG min 0
      Driver 3: ok, SG min 0
      Driver 4: standstill, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2022-12-01 01:11:53
      Slowest loop: 478.34ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 2.2ms, write time 559.7ms, max retries 0
      DMs created 83, segments created 14, maxWait 275333ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 41685, completed 41645, hiccups 5, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.4
      Heater 1 is on, I-accum = 0.3
      Segments left: 1
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X-11.541 Y-2.060 E0.0199" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 564.27ms; fastest: 0.00ms
      HTTP sessions: 2 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address 5c:cf:7f:f8:2b:ed
      WiFi Vcc 3.31, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25416
      WiFi IP address 192.168.1.191
      WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
        Can you try setting the Duet to access point mode and connecting to it directly? This would avoid your network situation.
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
        If that works, then you know the issue is with your network. If it doesn't, I would try manually updating your firmware to the latest and manually installing the updated DWC files to match.
        Ottobawtundefined 1 Reply Last reply Reply Quote 0
        • Ottobawtundefined
          Ottobawt @Phaedrux
          @Phaedrux
          I've been tinkering with this, and yes my network is surely the week point, but I'm not ready to setup the interface upgrade... I have found a work around but I need some help:
          I have two wireless access points, 1. A=giving me trouble 2. B= works, but if I cycle the power on the printer it automatically jumps back to "A", the only way I know to get it back on to "B" is to turn A's radio off, then run my m552 script for B, to connect to B... otherwise it just goes back to A. it's super weird, since A and B are both different SSID, Password, and Physical hardware... but the Duet's remember the login to A; I don't know where duet saves login information.
          in short: if both A and B wireless points are on, it will do everything it can to connect to A, however once connected to B it will stay on it until it disconnects/cycles.
          And both printers/versions of firmware act this way.
          How can I get it to just default to the last network it was connected to? or something of that nature?
            It will automatically connect to the access point that has the best signal strength.
            You could clear your currently save SSIDs and then only re-add the access point that works.
            Or you could change your config.g to specify the SSID you want to use.
            https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m552-set-ip-address-enabledisable-network-interface
            M552 S1 P"MyNetwork"
