    Unable to upload ANY files to Duet Wifi
    • divvet
      divvet last edited by
      Hi there,
      Don't know why but suddenly I am unable to upload any files, gcode or firmware. when ever I attempt to the progress bar goes up a few percent (changes with different files), shows a transfer rate, but doesn't actually progress at all and eventually ends in an error.
      I have tried swapping the SD card,
      I have tried updating the firmware
      Currently running Firmware and Wifi version 1.19.2 and web interface 1.19.3
      Originally had issues with 1.19.
      If anyone can give me some help I would appreciate it.
      • JohnOCFII
        JohnOCFII last edited by
        What web browser? You might try a different browser to see if you have the same behavior.
        • divvet
          oh sorry already tried.
          chrome: error as described
          firefox: oddly wont actually load the duet wifi webpage
          edge: dont get any progress on the progress bar and then proceeds to error
          Also tried on 2 different machines with the same issues.
          The only thing I can think of changing recently is the wifi ssid (same network, closer ap as I was getting frequent connection losses).
            Try clearing your browser cache in case it is using a version of the .js file from an older version of DWC.
            • divvet
              Unfortunately that did not work either.
              • divvet
                Don't know why, but the Duet seemed to take issue with my virtual access points. It connects fine but I got stupid delays after hitting connect, and the issue with the uploads.
                Just switched it to the main SSID of the router and everything works fine. Not ideally what I wanted to do, but sorts the issue for now.
                If this is of any concern to you at Duet then I can do any testing you want, otherwise forget I asked a question.
                Thanks for the help anyway 🙂
