    M31855k and PT100
    • c310undefined
      c310
      Hello! Is it possible to configure DuetWiFi with M31855k + PT100?
      RRF3.4
      direct PT100 reading is about 109 ohm (23' С seems to be correct)
      With this daughterboard i have connected 100 Ohm resistor. it reads 30'C, that is completely wrong..
      Configuration is
      IMG_20221203_163815.jpg IMG_20221203_163803.jpg ```
      M308 S1 P"spi.cs1" Y"thermocouple-max31855"
      M950 H1 C"e0_heat" T1
      So, questions
      1. is M31855k compatible with PT-100?
      2. if yes, what should i change in config to make it working ?
      Many thanks
        dc42 administrators @c310
        @c310 the MAX31855 chip is for interfacing to thermocouples only. It cannot interface to PT100 or PT1000 sensors.
        For PT100 sensors we make a similar daughter board that uses the MAX31865 chip.
