Skr H7 board and mini 12864 display
i try to connect an fystec mini v2.1 to the skr H7 board like here https://teamgloomy.github.io/skr_3_h723_screen_12864.html
but i cant use it because it stay dark. on an duet 3 mini it works without any problems but not with the skr. do i miss something ? i followed the guide without any change. do i have to modify something ?
@joeko post an output of M122 and M122 P200
@jay_s_uk said in Skr H7 board and mini 12864 display:
when i connect the esp2 connctor than the board cant connect to wifiM122
M122 === Diagnostics === RepRapFirmware for STM32H7 based Boards (biquskr_3) version 3.4.4_102 (2022-11-08 14:17:34) running on STM32H7 (standalone mode) Board ID: Z1044-0S2K2-D43SJ-6KKDD-GFLRZ-70000 Used output buffers: 3 of 40 (12 max) === RTOS === Static ram: 46792 Dynamic ram: 77144 of which 28 recycled Never used RAM 291540, free system stack 145 words Tasks: NETWORK(notifyWait,9.2%,252) HEAT(notifyWait,0.0%,344) Move(notifyWait,0.0%,354) CanReceiv(notifyWait,0.0%,934) CanSender(notifyWait,0.0%,331) CanClock(delaying,0.0%,332) TMC22xx(notifyWait,0.7%,149) FSWRITE(notifyWait,0.0%,568) MAIN(running,87.9%,977) IDLE(ready,2.1%,29), total 100.0% Owned mutexes: WiFi(NETWORK) BITIO(TMC22xx) === Platform === Last reset 00:01:27 ago, cause: power on/off Last software reset at 2022-12-08 16:39, reason: User, GCodes spinning, available RAM 291540, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 0 MCU temperature: min 30.5, current 39.2, max 39.8 Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill 2209, SG min 0, reads 7249, writes 9 Driver 1: standstill 2209, SG min 0, reads 7248, writes 9 Driver 2: standstill 2209, SG min 0, reads 7248, writes 9 Driver 3: standstill 2209, SG min 0, reads 7248, writes 9 Driver 4: Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Driver 12: Driver 13: Date/time: 2022-12-08 18:20:41 Slowest loop: 5.08ms; fastest: 0.03ms === Storage === Free file entries: 10 SD card 0 detected SD card longest read time 4.8ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 785, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 437/0/0 Tx timeouts 0,0,436,0,0,347 last cancelled message type 0 dest 1 === Network === Slowest loop: 24.40ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) HTTP sessions: 1 of 8 Uploads/Errors: 0/0 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Bad header: 0/0 WiFi firmware version 1.27-01S32-D WiFi MAC address 38:10:d5:02:b0:af WiFi Vcc 0.00, reset reason Power up WiFi flash size 0, free heap 144952 WiFi IP address 192.168.250.65 WiFi signal strength -23dBm, mode 802.11n, reconnections 0, sleep mode none Clock register 00002003 Socket states: 0 0 0 0 0 0 0 0
M122 P200 === Diagnostics === RepRapFirmware for STM32H7 based Boards (biquskr_3) version 3.4.4_102 running on STM32H7 at 480Mhz Bootloader: Unknown == Supported boards == Board 0.0: generic iomode 254 Signatures: Board 1.0: fly_super5 iomode 2 Signatures: 0x2fe7ccfb Board 2.0: fly_super8h7 iomode 2 Signatures: 0x32757276 Board 2.1: fly_super8_pro iomode 2 Signatures: 0x32757276 Board 3.0: biquskr_se_bx_2.0 iomode 4 Signatures: 0xf1832a2 Board 4.0: biquskr_3 iomode 2 Signatures: 0xaa36a0c4 Board 4.1: biquskr_3_ez iomode 2 Signatures: 0xaa36a0c4 == Configurable Board.txt Settings == board = biquskr_3 Signature 0xaa36a0c4 leds.diagnostic = A.13 leds.diagnosticOn = true leds.activity = NoPin leds.activityOn = true pins.SetHigh = {NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} pins.SetLow = {NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} stepper.powerEnablePin = NoPin stepper.enablePins = {D.6, D.1, E.0, C.7, D.13, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} stepper.stepPins = {D.4, A.15, E.2, D.15, D.11, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} stepper.directionPins = {D.3, A.8, E.3, D.14, D.10, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} stepper.digipotFactor = 0.00 stepper.TmcUartPins = {D.5, D.0, E.1, C.6, D.12, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} stepper.numSmartDrivers = 4 stepper.num5160Drivers = 0 stepper.spiChannel = 255 stepper.TmcDiagPins = {NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} heat.tempSensePins = {A.1, A.2, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} heat.spiTempSensorCSPins = {NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin, NoPin} heat.spiTempSensorChannel = 255 heat.thermistorSeriesResistor = 4700.00 atx.powerPin = E.4 atx.powerPinInverted = false atx.initialPowerOn = true sdCard.internal.spiFrequencyHz = 25000000 sdCard.external.csPin = NoPin sdCard.external.cardDetectPin = NoPin sdCard.external.spiFrequencyHz = 4000000 sdCard.external.spiChannel = 255 lcd.lcdCSPin = B.1 lcd.lcdBeepPin = NoPin lcd.encoderPinA = E.7 lcd.encoderPinB = B.2 lcd.encoderPinSw = B.0 lcd.lcdDCPin = E.8 lcd.panelButtonPin = NoPin lcd.spiChannel = 0 SPI0.pins = {A.5, A.6, A.7} SPI1.pins = {B.13, B.14, B.15} SPI2.pins = {NoPin, NoPin, NoPin} SPI3.pins = {E.14, E.15, E.13} SPI4.pins = {NoPin, NoPin, NoPin} SPI5.pins = {NoPin, NoPin, NoPin} SPI6.pins = {NoPin, NoPin, NoPin} SPI7.pins = {NoPin, NoPin, NoPin} SPI8.pins = {NoPin, NoPin, NoPin} 8266wifi.espDataReadyPin = B.10 8266wifi.lpcTfrReadyPin = B.11 8266wifi.TfrReadyPin = B.11 8266wifi.espResetPin = C.14 8266wifi.csPin = B.12 8266wifi.serialRxTxPins = {D.9, D.8} 8266wifi.spiChannel = 1 8266wifi.clockReg = 0 serial.aux.rxTxPins = {NoPin, NoPin} led.neopixelPin = E.10 power.VInDetectPin = NoPin power.voltage = 24 accelerometer.spiChannel = 255 == Defined Pins == bedtemp,tb = A.1 e0temp,th0 = A.2 e1temp,th1 = A.3 xstop = C.1 ystop = C.3 zstop = C.0 e0stop,e0det = C.2 e1stop,e1det = A.0 servo0 = E.5 probe = C.13 bed,hbed = D.7 e0heat,heat0 = B.3 e1heat,heat1 = B.4 fan0,fan = B.7 fan1 = B.6 fan2 = B.5 Neopixel = E.6 PSON = E.4 PWRDET = C.15 LED = A.13 BEEP = C.5 BTNENC = B.0 LCDEN = B.1 LCDRS = E.8 LCDD4 = E.9 LCDD5 = E.10 LCDD6 = E.11 LCDD7 = E.12 LCDMISO = A.6 LCDSCK = A.5 BTNEN1 = E.7 LCDSS = A.4 BTNEN2 = B.2 LCDMOSI = A.7 LCDCD = C.4 == Hardware Serial == AUX Serial: Disabled WIFI Serial: UART 3 == PWM == 0: Pin D.7 freq 0 value 0.000000 1: Pin B.3 freq 0 value 0.000000 2: Pin B.5 freq 0 value 0.000000 3: Pin B.6 freq 0 value 0.000000 4: Pin E.5 freq 0 value 0.000000 5: Pin E.9 freq 0 value 1.000000 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: == Attached interrupt pins == 0: 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: B.10 11: 12: B.12 13: 14: 15: == MCU == AdcBits = 14 TS_CAL1 (30C) = 12254 TS_CAL2 (110C) = 16303 V_REFINCAL (30C 3.3V) = 24142 V_REFINT raw 5992 V_REF 3.322029 T_MCU raw 3175 T_MCU cal 39.090908 T_MCU calc -23.186043 T_MCU raw (corrected) 3196 T_MCU cal (corrected) 40.766407 T_MCU calc (corrected) -21.478344 Device Id 450 Revison Id 2003 CPUId r1p1 == RAM == RAM start 0x24000000 end 0x24070000 No cache RAM 1 start 0x30000000 end 0x30048000 No cache RAM 2 start 0x24070000 end 0x24080000 == USB == Read overrun 0
i got it.
i had to change the connector to the oposite. wrong cable
