    Lowering Minimum Feed Rate in Duet2 WiFi
    • dieguitoundefined
      dieguito
      Hello, the minimum feed rate of the Duet WiFi is 30mm/min. How can I set it to 10 or 5mm/min? Thanks in advance!
        Check the M203 I parameter
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m203-set-maximum-feedrate
