    G28 Error: Probe already triggered at start of probing move
    IR Height Sensor
    • blacktoli
      blacktoli last edited by
      I have some issues since I updated the FW 3.4.4
      RepRapFirmware for Duet 2 Maestro 3.4.4
      I am using Duet IR sensor, and here is my config:
      M558 P1 C"zprobe.in" H2.5 F120 T3000
      G31 P500 X0 Y0 Z1.70
      Thanks
      Falcounet 1 Reply Last reply Reply Quote 0
      • Falcounet
        Falcounet @blacktoli last edited by
        @blacktoli Try inverting the pin :
        M558 P1 C"!zprobe.in" H2.5 F120 T3000
        and try with the help of M119 if the probe works correctly before probing the bed.
          Be careful inverting the pin. If it was functioning correctly before, inverting will either ignore the trigger and crash into the bed, or not move at all because it thinks it's triggered at the start.
          Check your wiring, check the sensor for debris.
          • blacktoli
            Thanks all for your help.
            It was the connector ffs. Thanks again
