    Is it possible work without heaters and sensors?
    ceramics cold extruder
    • GiusepRapundefined
      GiusepRap
      I want program a cold extruder for ceramics
      Regards
      Giuseppe
      • achrnundefined
        achrn
        I have a machine without any heaters, but actually I have defined sensors and a dummy heater so I can see if the board is overheating.
        I also have a thermistor crimped into a sensor connector and plugged on the board, and then:
        ; record processor temperature as sensor 1
        M308 S1 Y"mcu-temp" A"Processor"
        ; ambient temperature around board by 47k thermistor on 'bedtemp' connector
        ; (projects past side of board, remote from processor and steppers)
        M308 S2 P"bedtemp" Y"thermistor" T4701 B4266 C1.048787e-7 A"Ambient"
        ; sensor 3: overtemperature flag on stepper drivers (will report 0 for ok, 100 for warning or 130 for error
        M308 S3 Y"drivers" A"Drivers"
        ; define heater 1 as using the processor sensor
        ; output is on the expansion header just to be somewhere innocuous out of the way
        M950 H1 C"exp.heater7" T1
        ; specify a maximum temperature of 60C which will therefore be the graph scale in DWC
        M143 H1 S60
        This then has three sensors - one for the processor temperature, one for the air around the board, and one for the steppers drivers. It defines an out-of-the-way heater (with nothing connected), and in DWC the graph shows me a graph of processor temperature (which isn't very interesting, but tells me the board isn't overheating inside its enclosure).
        I don't have any extruder at all, but you could use M302 to allow for extrusion regardless of temperature.
          There's no need to create multiple posts for the same question.
          https://forum.duet3d.com/topic/30807/paste-estruder-configuration?_=1671579562280
          • Phaedruxundefined Phaedrux locked this topic
