    Voron 2.4 3MB6 §EB config issues.
    1.5k
    • Titus A Duxassundefined
      Titus A Duxass
      Greetings from Blaustein,
      First post here - first bunch of issues.
      I'm building (or have built) a Voron 2.4 with a 3 MB 6HC and a 3EB.
      Just for clarification, the 6 has two dud drivers (0 & 2) so I have the the Z drives on 1, 3, 4, 5 and A/B (X, Y) on the 3 along with the extruder.
      Yesterday I got the drives working how they should, this morning I have issues with Z.
      At first switch on there was no comm between the 6 and the 3 - the was no red led on the 3 - and then after about 20 mins it lit up and there was sync.
      So my first task was to confirm that the end stops are working - they are.
      Next was to home all 3 axis, X and Y perfect!
      Z nothing, so I went back to the console, repositioned the gantry to approx. 150 and moved them via the dash board. They all move as should but only about 100mm and then further clicking brings no results (is this normal?).
      I carried out a firmware update on both the 6 and 3 as part of the initial install.
      Below is the config.g.
      Can anyone see what my problem is?
      Thanks in advance.
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Dec 18 2022 17:39:32 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"voron" ; set printer name
      M669 K1 ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M584 X1.1 Y1.2 Z0.1:0.5:0.3:0.4 E1.0 ; set drive mapping
      M569 P1.1 S0 ; A motor goes forwards
      M569 P1.2 S0 ; B motor goes forwards
      M569 P0.1 S1 ; FL goes forwards
      M569 P0.5 S0 ; RL goes backwards
      M569 P0.3 S0 ; RR goes forwards
      M569 P0.4 S1 ; FR goes backwards
      M569 P1.0 S0 ; Extruder goes backwards
      M350 Z64 I0 ; configure microstepping without interpolation
      M350 X64 Y64 E64 I1 ; configure microstepping with interpolation
      M92 X320.00 Y320.00 Z400.00 E1746.16 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X60000.00 Y60000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1200 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S10 ; Set idle timeout
      M208 X290 Y290 Z250 S0 ; set axis maxima
      M574 X2 S1 P"^io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^io1.in
      M574 Y2 S1 P"^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^io2.in
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X40:260 Y40:260 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"Revo" D0 H1 F0:1 ; define tool 0
      ; Custom settings
      M584 Z0.1:0.5:0.3:0.4
      T0 ; select first tool
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Titus A Duxass
        @Titus-A-Duxass can you post an M122 B1 output? my guess would be you need to update the bootloader on the 3HC
        Also confirm the firmware on the 6HC using M115 (and post the output)
        Titus A Duxassundefined 1 Reply Last reply Reply Quote 0
          Titus A Duxass @jay_s_uk
          @jay_s_uk Hi and thanks for the quick response.
          Here is M122 B1
          21.12.2022, 10:20:48 M122 B1
          Diagnostics for board 1:
          Duet EXP3HC firmware version 3.3 (2021-06-15 16:12:41)
          Bootloader ID: not available
          Never used RAM 159104, free system stack 4395 words
          Tasks: Move(notifyWait,0.0%,100) HEAT(delaying,0.0%,104) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,80) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.2%,63) MAIN(running,91.5%,428) IDLE(ready,0.0%,39) AIN(delaying,1.3%,263), total 100.0%
          Last reset 00:35:20 ago, cause: software
          Last software reset data not available
          Driver 0: position 0, 1746.2 steps/mm, standstill, reads 13561, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
          Driver 1: position 44800, 320.0 steps/mm, standstill, reads 13559, writes 19 timeouts 0, SG min/max 0/165, steps req 44800 done 44800
          Driver 2: position 44800, 320.0 steps/mm, standstill, reads 13560, writes 19 timeouts 0, SG min/max 0/168, steps req 44800 done 44800
          Moves scheduled 12, completed 12, in progress 0, hiccups 0, step errors 0, maxPrep 60, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter -2/10, peak Rx sync delay 178, resyncs 0/0, no step interrupt scheduled
          VIN: 24.1V, V12: 12.2V
          MCU temperature: min 33.8C, current 36.5C, max 36.5C
          Ticks since heat task active 163, ADC conversions started 2120910, completed 2120910, timed out 0, errs 0
          Last sensors broadcast 0x00000000 found 0 168 ticks ago, loop time 0
          CAN messages queued 38, send timeouts 0, received 19102, lost 0, free buffers 37, min 37, error reg 110062
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 410, adv 36842/37068
          and M115
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 MB6HC v1.01 FIRMWARE_DATE: 2022-11-30 19:35:23
          Thanks
            @Titus-A-Duxass so your 3HC is running 3.3 and your 6HC is running 3.4.5 so you're out of sync there.
            you also need to update the bootloader on the 3HC. it can be found here https://github.com/Duet3D/Duet3Bootloader/releases/download/2.4/Duet3Bootloader-SAME5x.bin
            and instructions https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_bootloader
              @jay_s_uk I thought I read somewhere that after v3.3 it does not matter is they are out of sync. I will, nevertheless, update both the 3HC firmware and bootloader.
              Thanks, I'll be back.
                @Titus-A-Duxass they definitely need to be in sync as the protocol will change between updates
                  @jay_s_uk Okay updates carried out but 3EB firmware is still at 3.3.
                  M122
                  RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (standalone mode)
                  Board ID: 08DJM-9P63L-DJ3T8-6JKDA-3SJ6N-KB7MA
                  Used output buffers: 3 of 40 (18 max)
                  Static ram: 152760
                  Dynamic ram: 97336 of which 184 recycled
                  Never used RAM 100392, free system stack 208 words
                  Tasks: NETWORK(ready,30.8%,210) ETHERNET(notifyWait,0.1%,453) HEAT(notifyWait,0.0%,328) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,904) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.9%,91) MAIN(running,61.1%,925) IDLE(ready,0.1%,30), total 100.0%
                  Owned mutexes:
                  Last reset 00:02:23 ago, cause: power up
                  Last software reset at 2022-12-21 10:57, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 100392, slot 1
                  Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0xffd693d2 SP 0x2041b4f8 Task MAIN Freestk 1670 ok
                  Stack: 00000002 2042ecfc ffffffff 00000000 00000216 00489385 00488c2e 610f0000 ffffffff 2042c550 20419a84 2042d1ac 00000000 00000001 00000000 00488ee7 2042d1ac fdfc0000 003ff7ff 0048922f 042fffa0 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
                  Error status: 0x00
                  Step timer max interval 127
                  MCU temperature: min 34.3, current 41.7, max 41.7
                  Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                  Events: 0 queued, 0 completed
                  Driver 0: standstill, SG min 0, mspos 8, reads 13222, writes 11 timeouts 0
                  Driver 1: standstill, SG min 0, mspos 2, reads 13219, writes 14 timeouts 0
                  Driver 2: standstill, SG min 0, mspos 8, reads 13222, writes 11 timeouts 0
                  Driver 3: standstill, SG min 0, mspos 2, reads 13220, writes 14 timeouts 0
                  Driver 4: standstill, SG min 0, mspos 2, reads 13220, writes 14 timeouts 0
                  Driver 5: standstill, SG min 0, mspos 2, reads 13220, writes 14 timeouts 0
                  Date/time: 2022-12-21 11:00:12
                  Slowest loop: 21.07ms; fastest: 0.05ms
                  === Storage ===
                  Free file entries: 10
                  SD card 0 detected, interface speed: 25.0MBytes/sec
                  SD card longest read time 3.0ms, write time 0.0ms, max retries 0
                  DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  === AuxDDARing ===
                  Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty
                  === CAN ===
                  Messages queued 1305, received 41, lost 0, boc 0
                  Longest wait 2ms for reply type 6024, peak Tx sync delay 321, free buffers 50 (min 49), ts 720/719/0
                  Tx timeouts 0,0,0,0,0,0
                  === Network ===
                  Slowest loop: 18.51ms; fastest: 0.03ms
                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                  HTTP sessions: 1 of 8
                  = Ethernet =
                  State: active
                  Error counts: 0 0 0 1 0 0
                  Socket states: 5 2 2 2 2 0 0 0
                  === Multicast handler ===
                  Responder is inactive, messages received 0, responses 0
                  M122 B1
                  Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
                  Never used RAM 159104, free system stack 4400 words
                  Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,118) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.2%,63) MAIN(running,91.5%,439) IDLE(ready,0.0%,39) AIN(delaying,1.3%,263), total 100.0%
                  Last reset 00:02:14 ago, cause: power up
                  Driver 0: position 0, 1746.2 steps/mm, standstill, reads 60093, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
                  Driver 1: position 0, 320.0 steps/mm, standstill, reads 60094, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
                  Driver 2: position 0, 320.0 steps/mm, standstill, reads 60095, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
                  Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                  Peak sync jitter -1/8, peak Rx sync delay 180, resyncs 0/0, no step interrupt scheduled
                  MCU temperature: min 32.7C, current 33.9C, max 33.9C
                  Ticks since heat task active 80, ADC conversions started 134257, completed 134257, timed out 0, errs 0
                  Last sensors broadcast 0x00000000 found 0 85 ticks ago, loop time 0
                  CAN messages queued 36, send timeouts 0, received 1214, lost 0, free buffers 37, min 37, error reg 110064
                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                  21.12.2022, 11:01:45 M115 B1
                    @Titus-A-Duxass how are you trying to update the 3HC firmware?
                      @jay_s_uk as per - https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                        @Titus-A-Duxass so you're uploading the 3HC firmware file to the system tab?
                          @jay_s_uk I follow the instructions on that page.
                          Download the file (Duet2and3firmware-345.zip)
                          and then upload via the DWC
                          Upload System Files button.
                            @Titus-A-Duxass i don't know why its not updating that way then.
                            you could try turning the machine off, and turning all the dip switches off on the 3HC. This causes the board to request and update the firmware on startup https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_3HC#address
                            can you also check what version of DWC you're running? it shows under general settings
                              @jay_s_uk Thanks, that forced it -
                              21.12.2022, 11:21:12 M115 B1
                              Duet EXP3HC rev 1.01 or earlier firmware version 3.4.4 (2022-10-14 11:45:56)
                              21.12.2022, 11:22:45 M122 B1
                              All averaging filters OK
                              Never used RAM 158932, free system stack 200 words
                              Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.4%,99) MAIN(running,91.2%,441) IDLE(ready,0.0%,40) AIN(delaying,1.3%,263), total 100.0%
                              Last reset 00:02:06 ago, cause: power up
                              Driver 0: pos 0, 1746.2 steps/mm,standstill, SG min 0, mspos 2, reads 27429, writes 16 timeouts 0, steps req 0 done 0
                              Driver 1: pos 0, 320.0 steps/mm,standstill, SG min 0, mspos 2, reads 27430, writes 16 timeouts 0, steps req 0 done 0
                              Driver 2: pos 0, 320.0 steps/mm,standstill, SG min 0, mspos 2, reads 27430, writes 16 timeouts 0, steps req 0 done 0
                              Peak sync jitter -1/8, peak Rx sync delay 178, resyncs 0/0, no step interrupt scheduled
                              VIN voltage: min 24.1, current 24.2, max 24.2
                              V12 voltage: min 12.2, current 12.2, max 12.2
                              MCU temperature: min 32.5C, current 33.8C, max 33.9C
                              Last sensors broadcast 0x00000000 found 0 173 ticks ago, 0 ordering errs, loop time 0
                              CAN messages queued 1045, send timeouts 0, received 1146, lost 0, free buffers 37, min 37, error reg 0
                              M122
                              Static ram: 152760
                              Dynamic ram: 97332 of which 184 recycled
                              Never used RAM 100396, free system stack 202 words
                              Tasks: NETWORK(ready,31.9%,210) ETHERNET(notifyWait,0.1%,441) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.9%,91) MAIN(running,60.0%,925) IDLE(ready,0.1%,30), total 100.0%
                              Owned mutexes:
                              Last reset 00:02:34 ago, cause: power up
                              Last software reset details not available
                              Error status: 0x00
                              Step timer max interval 126
                              MCU temperature: min 33.1, current 41.5, max 41.6
                              Driver 0: standstill, SG min 0, mspos 8, reads 6751, writes 11 timeouts 0
                              Driver 1: standstill, SG min 0, mspos 2, reads 6748, writes 14 timeouts 0
                              Driver 2: standstill, SG min 0, mspos 8, reads 6751, writes 11 timeouts 0
                              Driver 3: standstill, SG min 0, mspos 2, reads 6748, writes 14 timeouts 0
                              Driver 4: standstill, SG min 0, mspos 2, reads 6748, writes 14 timeouts 0
                              Driver 5: standstill, SG min 0, mspos 2, reads 6749, writes 14 timeouts 0
                              Date/time: 2022-12-21 11:23:11
                              Slowest loop: 21.06ms; fastest: 0.05ms
                              === Storage ===
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              Code queue is empty
                              === CAN ===
                              Messages queued 1401, received 1276, lost 0, boc 0
                              Longest wait 2ms for reply type 6024, peak Tx sync delay 6, free buffers 50 (min 49), ts 773/772/0
                              === Network ===
                              Slowest loop: 17.69ms; fastest: 0.03ms
                              = Ethernet =
                              State: active
                              Error counts: 0 0 0 0 0 0
                                @Titus-A-Duxass fantastic. now go back to using your printer as you were before and see if you still have issues. there are a few of us (me included) that run v2.4's with RRF
                                  dc42 administrators @Titus A Duxass
                                  @Titus-A-Duxass so is it working now or are there still problems?
                                  How did two drivers on the 6HC come to be faulty?
                                    Titus A Duxass @dc42
                                    @dc42 No it still has issues.
                                    X and Y home as should.
                                    Z motors along to 0X0Y and then hangs until it times out, you can here some motors running.
                                    I bought the board knowing that the two drivers are kaputt, I suspect that there are more failures on the board.
                                    So I either have to find another board or strip it out and fit a BTT Manta M8P that I have. This is not something that I want to do as a it means replacing all the connectors.
                                      @Titus-A-Duxass can you try downgrading the mainboard to 3.4.4?
                                      Titus A Duxassundefined 2 Replies Last reply Reply Quote 0
                                        @jay_s_uk Wait - my mistake! The Z is homing, it's just going extremely slow! Should be done about Tuesday.
                                          @Titus-A-Duxass said in Voron 2.4 3MB6 §EB config issues.:
                                          You should remove that line. Endstop mode S2 is used only when the Z probe is used to home axes other than Z.
                                          Please post your homeall.g and homez.g files.
                                            @jay_s_uk Oops!
                                            21.12.2022, 11:34:07 G28 Z
                                            Error: Probe was not triggered during probing move
                                            This happened with the Z at about +100mm
