Running Heaters
Can anyone guide me, how to run heaters? Which GCode should be used to run heaters? In the configuration file, heaters are defines as follows:
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"spi.cs1" Y"thermocouple-max31856" K"T" ; configure sensor 1 as thermocouple via CS pin spi.cs0
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M308 S2 P"spi.cs2" Y"thermocouple-max31856" K"T" ; configure sensor 2 as thermocouple via CS pin spi.cs1
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280C
M308 S3 P"spi.cs3Y6" Y"thermocouple-max31856" K"T" ; configure sensor 3 as thermocouple via CS pin spi.cs2
M950 H3 C"out3" T3 ; create nozzle heater output on out3 and map it to sensor 3
M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H3 S280 ; set temperature limit for heater 3 to 280Cnow how can I run them, using M104 GCode?
One thread is enough thanks.
undefined Phaedrux locked this topic
