Magnetic Filament Sensor error
Good morning, during my prints I keep on having a "Sensor error" wich pause the print itself, here's the M122:
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later Board ID: 08DLM-996RU-N85T0-6JKFJ-3SD6R-9SSHN Used output buffers: 10 of 26 (26 max) === RTOS === Static ram: 23836 Dynamic ram: 76120 of which 0 recycled Never used RAM 8020, free system stack 98 words Tasks: NETWORK(notifyWait,16.6%,211) HEAT(notifyWait,0.0%,312) Move(notifyWait,2.7%,282) MAIN(running,80.6%,438) IDLE(ready,0.1%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:35:03 ago, cause: software Last software reset at 2022-12-23 10:54, reason: User, GCodes spinning, available RAM 8140, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.6, current 33.5, max 34.0 Supply voltage: min 23.6, current 23.8, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/130/0, gc cycles 0 Events: 1 queued, 0 completed Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min 0 Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2022-12-23 11:29:22 Cache data hit count 4294967295 Slowest loop: 144.54ms; fastest: 0.10ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 8 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.3ms, write time 45.2ms, max retries 0 === Move === DMs created 83, segments created 52, maxWait 135763ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 42258, completed 42258, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.4 === GCodes === Segments left: 0 Movement lock held by Autopause HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is doing "G4 S20 " in state(s) 0 28, running macro Code queue is empty === Filament sensors === Extruder 0: pos 318.16, errs: frame 0 parity 0 ovrun 0 pol 1 ovdue 0 === Network === Slowest loop: 131.42ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1) HTTP sessions: 2 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address 84:0d:8e:b3:bc:96 WiFi Vcc 3.45, reset reason Turned on by main processor WiFi flash size 4194304, free heap 22368 WiFi IP address 192.168.1.7 WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 2 0 4 0 0 0 0 0```
Used output buffers: 7 of 26 (26 max)
Static ram: 23836
Tasks: NETWORK(notifyWait,16.1%,211) HEAT(notifyWait,0.0%,312) Move(notifyWait,2.7%,282) MAIN(running,81.2%,438) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:48:13 ago, cause: software
Error status: 0x04
Aux0 errors 0,0,0
MCU temperature: min 33.2, current 33.7, max 34.1
Supply voltage: min 23.7, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Events: 2 queued, 1 completed
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2022-12-23 11:42:31
Slowest loop: 19.88ms; fastest: 0.10ms
=== Storage ===
SD card longest read time 1.4ms, write time 1.5ms, max retries 0
DMs created 83, segments created 52, maxWait 53979ms, bed compensation in use: mesh, comp offset 0.000
=== MainDDARing ===
Scheduled moves 58544, completed 58544, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Code queue is empty
Extruder 0: pos 329.77, errs: frame 0 parity 0 ovrun 0 pol 1 ovdue 0
=== Network ===
Slowest loop: 100.34ms; fastest: 0.09ms
= WiFi =
Failed messages: pending 0, notready 0, noresp 2
WiFi Vcc 3.44, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24248
WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0Any Idea? Duet 2WiFi
@TheDragonLord do the filament sensor wires run close to any stepper motor wires?
What AGC value does the filament sensor report?
@dc42 said in Magnetic Filament Sensor error:
yes....
@TheDragonLord in that case, I recommend you use shielded cable to connect the filament monitor. You can use the shield as the ground connection, so 2 cores + shield is sufficient.
I already use a shielded cable
@TheDragonLord what AGC value does the sensor report? Send M591 D# where # is the extruder number to check.
