Setting individual array element variables (V3.5.0b1)
@OwenD were you using he latest commit of RRFLibraries from the 3.5-dev branch when you built RRF for Duet 2?
@dc42 said in Setting individual array element variables (V3.5.0b1):
Yes I believe so, downloaded a few hours ago.
Previously I was using 3.4-dev RRFLibraries, but had to change to 3.5-dev to get it to compile this time.
I use this batch file (entering 3.5-dev)@echo off set /p Version="Enter full version e.g. 3.4-dev : " cd C:\Eclipse\ del /f /s /q "C:\Eclipse\Firmware\*.*" rmdir /s /q "C:\Eclipse\Firmware" mkdir "C:\Eclipse\Firmware" cd "C:\Eclipse\Firmware" git clone https://github.com/Duet3D/ReprapFirmware.git -b %Version% git clone https://github.com/Duet3D/CANlib.git -b %Version% git clone https://github.com/Duet3D/CoreN2G -b %Version% git clone https://github.com/Duet3D/FreeRTOS -b 3.4-dev git clone https://github.com/Duet3D/RRFLibraries -b %Version% git clone https://github.com/Duet3D/DuetWiFiSocketServer -b dev echo ... echo **** press enter to exit **** pause >nul exit
@OwenD I found an issue when the Z probe has temperature coefficients specified in the G31 command, that could explain your reset. It should be fixed by the latest commit. Thanks for reporting this.
Setting elements works for me too with your build, many thanks!
Now, before I convert all my code to use this style, is there something obviously bad/wrong with me defining my data like this? I know it's quite verbose, but this way it's easier to "see" the contents since these image data...;Digits global displayDigit = vector(10, null) ;0 set global.displayDigit[0] = vector(8, null) set global.displayDigit[0][0] = {0,1,1,1,1,1,1,0} set global.displayDigit[0][1] = {1,1,1,1,1,1,1,1} set global.displayDigit[0][2] = {1,1,1,0,0,1,1,1} set global.displayDigit[0][3] = {1,1,1,0,0,1,1,1} set global.displayDigit[0][4] = {1,1,1,0,0,1,1,1} set global.displayDigit[0][5] = {1,1,1,0,0,1,1,1} set global.displayDigit[0][6] = {1,1,1,1,1,1,1,1} set global.displayDigit[0][7] = {0,1,1,1,1,1,1,0} ;1 set global.displayDigit[1] = vector(8, null) set global.displayDigit[1][0] = {0,0,1,1,1,0,0,0} set global.displayDigit[1][1] = {0,0,1,1,1,1,0,0} set global.displayDigit[1][2] = {0,0,1,1,1,1,1,0} set global.displayDigit[1][3] = {0,0,1,1,1,0,0,0} set global.displayDigit[1][4] = {0,0,1,1,1,0,0,0} set global.displayDigit[1][5] = {0,0,1,1,1,0,0,0} set global.displayDigit[1][6] = {0,0,1,1,1,0,0,0} set global.displayDigit[1][7] = {0,0,1,1,1,0,0,0} ;2 set global.displayDigit[2] = vector(8, null) set global.displayDigit[2][0] = {0,1,1,1,1,1,1,0} set global.displayDigit[2][1] = {1,1,1,1,1,1,1,1} set global.displayDigit[2][2] = {1,1,1,0,0,1,1,1} set global.displayDigit[2][3] = {0,1,1,1,0,0,0,0} set global.displayDigit[2][4] = {0,0,0,1,1,1,0,0} set global.displayDigit[2][5] = {0,0,0,0,0,1,1,1} set global.displayDigit[2][6] = {1,1,1,1,1,1,1,1} set global.displayDigit[2][7] = {1,1,1,1,1,1,1,1} ;3 set global.displayDigit[3] = vector(8, null) set global.displayDigit[3][0] = {0,1,1,1,1,1,1,1} set global.displayDigit[3][1] = {1,1,1,1,1,1,1,1} set global.displayDigit[3][2] = {1,1,1,0,0,0,0,0} set global.displayDigit[3][3] = {0,1,1,1,1,1,1,1} set global.displayDigit[3][4] = {0,1,1,1,1,1,1,1} set global.displayDigit[3][5] = {1,1,1,0,0,0,0,0} set global.displayDigit[3][6] = {1,1,1,1,1,1,1,1} set global.displayDigit[3][7] = {0,1,1,1,1,1,1,1}
If there's no technical problem you can think of, I'd continue to use this style for my "image" data.
@Diamondback you could start with this:
global displayDigit = vector(10, vector(8,null))
I don't see any other way to improve it unless the individual vectors are sufficiently related so that you can calculate them algorithmically.
@dc42 Oh right, good point, thanks Yea the data is unfortunately all "art", so I don't see how I could automate that.
FYI
I just compiled the latest commit again and the resets appear to have stopped. -
@Diamondback If your "art" becomes too big, you could still offload it to an SBC plugin in the next v3.5-b2. If a third-party SBC plugin exposes plugin data and you reference it in expressions (e.g. via
plugins.myArtPlugin.data.foo
), that data is replaced in expressions before it is evaluated by RRF.
