Bltouch Duet2 WIFI crash
This post is deleted! -
@Herve_Smith Thanks you !! it work do you have the probe map file for creality ?
@Herve_Smith LOL but your Mesh.g contain your M557 ?
@Herve_Smith Thank you very much for all your advice I just have 2 last questions how do I define on the machine that the BLTouch is 45mm to the left of the nozzle. and can i have your grid map please.
@Herve_Smith Good evening all the home works perfectly but I have another problem I don't see how to adjust the offset between the probe and the nozzle I know that I know in the G31 command but I don't understand how it works because the home works a la perfection in X and Y but the nozzle is at least 0.5 cm from the bed and the BLTouch does not retract so when I go down the Z axis the sensor blocks and displays the values 1000 it looks like a kind of security
@Iker Do you have the BLTouch mounted at the correct height?
With the probe retracted and the nozzle touching the bed, you should have 2.3-4.3mm from the bed to the end of the probe.To measure
- Start printer
- Send
G28 X Y
; Home X & Y only - Send
M564 S0 H0
; allow movement without homing - Jog to centre of bed
- If needed, send
M280 P0 S80
; retract BLTouch - Place piece of paper on bed
- Jog Z axis down until nozzle just grabs paper
- Adjust BL Touch mounting position to correct height per drawing
- Send
G92 Z0
; set Z axis position to zero - Jog Z axis up about 10mm to clear bed and remove paper
- Send
G30 S-1
to measure Z probe offset in Z direction - Take not of reported measurement.
- Follow instructions here to measure probe offset in X & Y directions
- Adjust config.g and restart printer
