[3.5.b1] Loading filament via DWC does not work
Not sure why exactly, but when I try to load a filament via the DWC filament feature, it doesn't work anymore in 3.5b1. It executes a bunch of code in my load macro, but then suddenly gets stuck after displaying a message box that I need to ack. The printer then just gets stuck in Busy state until I manually reset it.
Any ideas?
Here's a typical load macro:
var extrusionTemp = var.T var extrusionMinTemp = var.S var retractionMinTemp = var.R set global.pebbleFeedSpeed = var.F ;apply commanded pebble feed speed M98 P"/macros/Misc/Lights/On" M291 P"Heating for purge" R"Filament" S0 T5 M98 P"/macros/Toolchanging/HomeIfNotHomed" M568 P{state.currentTool} S{var.extrusionTemp} R0 M116 P{state.currentTool} M302 S{var.extrusionMinTemp} R{var.retractionMinTemp} ;Cold extrusion settings M98 P"/macros/Misc/Beep" M291 P"Ready to load new filament?" R"Filament" S2 G4 S2 G1 E75 M98 P"/macros/Tool/Purge" M98 P"/macros/Tool/Cooldown" M98 P"/macros/Misc/Beep" As far as I can tell, it executes things corretly until after the M291 S2 (line 13), but none of the following stuff is ever executed.
Update: This seems to be a DWC issue, downgrading the firmware to 3.4.5 while leaving DWC at 3.5b1 did NOT solve the problem, only downgrading DWC to 3.4.5 as well helped.
@chrishamm maybe? I can successfully use RRF 3.5b1 with 3.4.5 DWC, but with 3.5b1 DWC it fails.
@Diamondback I believe this is caused by the blocking message box. I am investigating.
@chrishamm Yes, it's the message box handling. Currently you can work-around this bug by sending
M292
only using the DWC input, although I understand it isn't ideal. The corresponding bug fix will be part of 3.5-b2. -
Awesome, thank you. Is the duplication in the check from this commit the culprit?
https://github.com/Duet3D/DuetWebControl/commit/8b9c4ef816f5559e56c324625336deb0c43c963e -
@Diamondback Yes, it is. Stupid typo.
@chrishamm Oh well, it happens
Not the first time, not the last time
