    Accurate stall detection using the 1HCL
    • tristanryerparkeundefined
      tristanryerparke
      Hello all,
      I’ve got a cartesian machine running 5x 1HCL boards all running 3.4.5 stable. For while I was using the closed loop function on the boards, working great but noisy and high-speed feedrates were limited.
      I noticed that on power up the machine can still generate driver-error events when axes are moved/crashed, before tuning is run. The machine operates much quieter and faster in open-loop mode, so I’m wondering if it’s possible to only use the encoders for position confirmation/stall detection. If so could anyone provide an ideal sequence of commands to enable this?
      Thanks,
      T
      dc42undefined 1 Reply Last reply Reply Quote 1
        dc42 administrators @tristanryerparke
        @tristanryerparke this isn't supported yet but I will add it to the wish list.
        I expect to increase the maximum step speed of the EXP1HCL in a future firmware release, and I hope to make it quieter too.
