    Duet WiFi new hot end
    • kivlowundefined
      kivlow
      Hello 😆
      i buy new hot end a red lizzard HF like is this link :
      https://www.aliexpress.com/item/1005003839228285.html?spm=a2g0o.order_list.order_list_main.5.21ef1802I1GKu1
      i set
      M305 P1 T100000 B4138 C0 R3950
      M143 H1 S350
      but my temp chart is mega floating up down +- 10stC
      what i can tweek to get better stability
      Regard Kamil
      pic - this is mega stable under +-10stC but normal is over +-15stC
      printer in home stable 22stC no wind.
      • OwenDundefined
        OwenD
        If you're running RRF3.0 or later then you should use M308, not M305.
        Those dips look like they may be noise due to a bad crimp or something.
        Probably best to check that and to come back wit what firmware version you're using and full config.g
