    RRF bracket notation in mathematical equation - syntax question
    Gcode meta commands
    • Wurkeundefined
      Wurke
      Id like to run a few calculations.
      for example (1 + 2) * 3 = 9 is not he same as 1+2*3 = 7 because of the bracket notation. But how do you implement this in RRF? Round brackets don't work and curly brackets don't work either. Is the only way to separate the sum in to multiple parts?
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Wurke
        @Wurke
        You do it pretty much exactly as you've written it.
        If you're trying to use it inside a parameter, you may need to use curly brackets {} around the entire equation
        M291 R{"The value is" ^ (1=2)*3} S1 T2
        You do have to be running RRF 3.1 or later
        Wurkeundefined 1 Reply Last reply Reply Quote 1
        • Wurkeundefined
          Wurke @OwenD
          @OwenD Thanks. I must have been getting errors from another section of code.
          OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • OwenDundefined
            OwenD @Wurke
            @Wurke
            If you're doing your code in a text editor, make sure it uses Unix style line ends. LF only, not CRLF
            Otherwise the line numbers reported in errors will be out.
              dc42 administrators @Wurke
              @Wurke if you are running your machine in CNC mode then characters inside round brackets are normally treated as comments as per the NIST standard. You can get around this by enclosing the entire expression in { }, for example:
              echo {(1+2)*3}
                dc42 administrators @OwenD
                @OwenD said in RRF bracket notation in mathematical equation - syntax question:
                @Wurke
                This will be fixed in RRF 3.5beta2.
