    Possible bug in control during "Changing tool"?
    PanelDue
    • Gone2Farundefined
      Gone2Far
      It appears the Panel Due is unable to communicate with the DuetWifi while the hotend is heating. All using the Panel Due: set the hotend temp, and make the hotend active. Status went to "Changing Tool", and hotend started heating. At this point I found the hotend fan wasn't working (my fault), and tried to cancel the heater activation. Was not able to do so. Even the STOP button was ineffective. Had to power off printer. Experimenting, it seems to return to normal once "Changing Tool" goes away. Is this expected, that the STOP button does not work while in this state?
      Running 1.2b6, Panel Due v3.
      Original Prusa i3 MK2S
      Large Kossel Homebrew
        That is a known issue.
        • Gone2Farundefined
          Gone2Far
          Thanks!
