Edit Default Macros
I would like to edit the default macros found in the web console. Specifically, I'm looking to edit the "Extrusion Control" on the Dashboard and increase the amounts of extrusion from 100mm to (something larger). Can someone point me the in direction of where I can find the files to edit. I found this page, https://duet3d.dozuki.com/Wiki/Macros and searched the linked github repository but couldn't find it there. Thanks in advance. -
On my laptop (ie no mouse), I would click to select let's say the 100 mm extrusion box. I then right click with two fingers (and I do not know what button that relates to on a mouse) and up comes a box that lets you change the '100 mm' setting to whatever you want.
@jens55 Thanks!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
