    Duet 3 mini Expansion
    287
    • Proschi3Dundefined
      Proschi3D
      Is it possible to expand the IO inputs on the Duet 3 mini?
      I have all but one occupied and would like to control two more rc servos.
      Otherwise I would have to home the Y axis sensorless to get an input free
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      cosmowaveundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @Proschi3D
        @Proschi78 Perhaps with a toolboard?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          dc42 administrators @Proschi3D
          @Proschi78 if you are not using a temperature daughter board, you can use the two CS pins on the connector as additional inputs or non-PWM outputs. Be careful because there is no protection on those pins.
          Proschi3Dundefined 1 Reply Last reply Reply Quote 1
            Proschi3D @dc42
            @dc42 thanks I will try it on the CS pins
            Proschi3Dundefined 1 Reply Last reply Reply Quote 0
              Proschi3D @Proschi3D
              @Proschi78
              ok i have now connected the servo to spi2.cs1.
              ;Servo configuration
              M950 S1 C"spi2.cs1" ; assign GPIO port 1 to out9 (Servo header), servo mode
              what command do i use to move it now?
              M280 P# S80 ?
                @Proschi78 you asked about expanding the IO inputs. To control a servo, you need an output, and it must be PWM-capable. The SPI CS pins can be used as low-current outputs, but they are not PWM-capable.
                Do you have any of the four low-current outputs free? They can be used to drive servos, in conjunction with an external pullup resistor. Connect the OUTn_NEG pin of the output to the servo control wire, and connect a resistor in the range 2K to 10K between that connection and +5V. You will need to get +5V and GND for the servo from a different connector. Be careful not to connect the servo to the VFAN [in of the OUT connector by mistake.
                  Proschi3D @dc42
                  @dc42 ok then i could put a filament sensor or limit switch on a cs in right?
                    @Proschi78 said in Duet 3 mini Expansion:
                    Yes.
                    It's OK to use the input and output pin of an IO connector for different purposes, for example to drive a hobby servo and read and endstop.
                      Proschi3D @dc42
                      @dc42 OK thank you
                      then I will solve it like this
