Solved No WiFi signal strength : Duet WiFi Server Version: 2.1beta2
When updating the WiFi server to 2.1beta2 the WiFi signal remains at zero
M122 reports of old and new WiFi server versions for comparisonFirmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5beta1+ (2023-01-20)
Duet WiFi Server Version: 2.1beta2M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta1+ (2023-01-20 21:58:22) running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD Used output buffers: 23 of 26 (23 max) === RTOS === Static ram: 22188 Dynamic ram: 79136 of which 0 recycled Never used RAM 8644, free system stack 192 words Tasks: NETWORK(notifyWait,10.9%,233) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,336) Move(notifyWait,0.0%,362) MAIN(running,87.7%,490) IDLE(ready,1.4%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:01:04 ago, cause: software Last software reset at 2023-01-21 12:03, reason: User, Gcodes spinning, available RAM 7080, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x08 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 31.7, current 32.4, max 32.8 Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/384/116, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok, SG min n/a Driver 1: ok, SG min n/a Driver 2: ok, SG min n/a Driver 3: ok, SG min n/a Driver 4: ok, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-01-21 16:30:27 Cache data hit count 2714556405 Slowest loop: 6.10ms; fastest: 0.13ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.9ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 18.91ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 2.1beta2 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Power up WiFi flash size 4194304, free heap 34588 WiFi IP address 192.168.1.163 WiFi signal strength 0dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
Board: Duet 2 WiFi (2WiFi)
Duet WiFi Server Version: 1.27M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta1+ (2023-01-20 21:58:22) running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD Used output buffers: 1 of 26 (24 max) === RTOS === Static ram: 22188 Dynamic ram: 79136 of which 0 recycled Never used RAM 8644, free system stack 192 words Tasks: NETWORK(notifyWait,16.0%,146) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,330) Move(notifyWait,0.0%,362) MAIN(running,83.9%,490) IDLE(ready,0.0%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:05:37 ago, cause: software Last software reset at 2023-01-21 12:03, reason: User, Gcodes spinning, available RAM 7080, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x08 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 31.7, current 32.3, max 32.7 Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/384/116, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok, SG min n/a Driver 1: ok, SG min n/a Driver 2: ok, SG min n/a Driver 3: ok, SG min n/a Driver 4: ok, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-01-21 16:34:59 Cache data hit count 4294967295 Slowest loop: 21.61ms; fastest: 0.06ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.0ms, write time 22.1ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 1208.00ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address bc:dd:c2:89:a0:bb WiFi Vcc 3.38, reset reason Power up WiFi flash size 4194304, free heap 23272 WiFi IP address 192.168.1.163 WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@OwenD this is a known issue, fixed in the next beta.
