    Configuring NEMA 23 on a DUET 2 WIFI
    CNC
    • Stef64Frundefined
      Stef64Fr
      Hi there,
      I'm currently building a CNC with a DUET 2 WIFI and NEMA 23 Steppers (23HD86001Y-21B).
      I've tested most of the features with NEMA 17 and all worked fine.
      Switching to NEMA 23 (with relevant settings (a priori) Steppers are quiet noisy, with a "Phase A might be disconnected" in addition. Moreover if move is above 5cm direction of move is lost, and stepper behavior becomes random, going whatever direction "it decides".
      I've calcultated on RepRapFirmware NEMA 23 settings thus applying them as advised.
      I clearly did not succeed in several attemps to vary motor settings parameters.
      I'm a bit lost... The 4 NEMA's behave the same way.
      DUET 2 is configured as follow :
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sat Jan 14 2023 17:54:34 GMT+0100 (heure normale d’Europe centrale)
      M550 P"CNC Musset" ; set printer name
      ;M551 P"Cylogie@2015" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M584 X0:1 Y2 Z3 ; set drive mapping
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X2560.00 2560.00 Z2560.00 ; set steps per mm
      M566 X100.00 Y100.00 Z25.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X420.00 Y420.00 Z140.00 ; set maximum speeds (mm/min)
      M201 X50.00 Y50.00 Z20.00 ; set accelerations (mm/s^2)
      M906 X3000 Y3000 Z3000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X780 Y660 Z45 S0 ; set axis maxima
      M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M140 H-1 ; disable heated bed (overrides default heater mapping)
      ; Emergency stop
      M950 J1 C"e1stop"
      M581 P1 T0 S1 R0
      ; PanelDue
      M575 P1 S1 B57600
      Thx in advance for your support,
      Stéphane (Paris, France)
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Stef64Fr
        @Stef64Fr said in Configuring NEMA 23 on a DUET 2 WIFI:
        (23HD86001Y-21B
        the datasheet says 3 A for the stepper, the setting for M906 shall be about 60 to 80% of that, so a setting of about 1800 to 2400 would be the value to be set, because Duet 2 Wifi has a maximum of 2.4 A. I would make sure the board is cooled enough. (probably the backside of the board needs to be cooled)
        Please see https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_configuring section Setting motor currents
        I would also check that the wiring is correct in advance, e.g. checking the pairwise wiring. There is also documentation how to do this (measuring with an ohmmeter or by hand). Maybe coloring of all steppers are different than expected. Please see https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_connecting
        section Using the internal drivers
        Stef64Frundefined 1 Reply Last reply Reply Quote 0
        • Stef64Frundefined
          Stef64Fr @JoergS5
          Hi Joerg,
          Many thanks for your quick answer.
          I've tested the 2400mA. Does not change much. Behaviour remains the same. Maybe a little bit less noisy.
          About wiring, you are right. My steppers do not respect standard colors. That was one of the first checks I've done so far.
          Carrying on with the reading of articles you've advise me to do so.
          Have a nice day,
          Stéphane
          • JoergS5undefined
            JoergS5 @Stef64Fr
            @Stef64Fr good luck to find the reason. I hope you'not damaged your board, you can make M122 to check the driver status with steppers where you know they work. I've no other idea what you can check.
