    DWC CNC Jog errors
    Duet Web Control
    • wayneosdiasundefined
      wayneosdias
      I keep getting DWC CNC "Error: G1: expected number after 'u'" and no movement when using the jog commands in DWC CNC. Im able to enter G0/G1 commands manually in the console with no issue and correct movment. What am I doing wrong?
      Ver;
      Board: Duet 3 Mini 5+ (Mini5plus)
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0 (2022-03-15)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.5.0-b1
      Config;
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Jan 15 2023 14:06:38 GMT-0800 (Pacific Standard Time)
      G90                                               ; send absolute coordinates...
      M550 P"BBE Printer"                    ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.0 S0 D3 V40                     ; physical drive 0.0 goes forwards
      M569 P0.1 S0 D3 V40                     ; physical drive 0.1 goes forwards
      M569 P0.2 S0 D3 V40                     ; physical drive 0.2 goes forwards
      M569 P0.3 S1 D3 V40                     ; physical drive 0.3 goes forwards
      M584 X2 Y3 V1 U0
      ; set drive mapping
      M350 X16 Y16 V16 U16 I1                                  ; configure microstepping with interpolation
      M92 X80.00 Y80.00 V3200.00 U3200.00            ; set steps per mm
      M566 X900.00 Y900.00 V100.00 U100.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 V1000.00 U1000.00  ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 V20.00 U20.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 V600 U600 I30                        ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                              ; Set idle timeout
      M208 X0:220 Y0:110 V0:48 U0:48
      M574 X0 S1 P"io2.in"  ; configure active low endstop switch for low end on X (Duet 3)
      M574 Y0 S1 P"io4.in"  ; configure active low endstop switch for low end on X (Duet 3)
      M574 U2 S1 P"!io6.in"  ; configure active low endstop switch for low end on X (Duet 3)
      M574 V2 S1 P"!io5.in"  ; configure active low endstop switch for low end on X (Duet 3)
      ;Config for CNC
      M453
      M950 R0 C"out0"
      M563 P1 S"Tool1" R0
      M950 R1 C"out1"
      M563 P2 S"Tool2" R1
      G54
      ;G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      ;G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      ;global Servo1=95
      ;global Servo2=95
        jay_s_uk @wayneosdias
        @wayneosdias it's a known issue with 3.5b1
        Also, don't fix and match firmware and DWC versions! Keep the firmware and DWC versions the same
        wayneosdiasundefined 1 Reply Last reply Reply Quote 1
          wayneosdias @jay_s_uk
          @jay_s_uk Ok Thanks, if I want to use the btncmd plugin in DWC, whats the latest latest FW/DWC in can roll back too? The only DWC version I could get the btncmd plugin to work was 3.5.
          MintyTreborundefined 1 Reply Last reply Reply Quote 0
          • MintyTreborundefined
            MintyTrebor @wayneosdias
            @wayneosdias Download a previous version of BtnCmd from github, eg https://github.com/MintyTrebor/BtnCmd/releases/tag/Beta_0.10.15 will work with DWC3.4. The release notes for each release state which version of DWC they work with.
            NodeDSF - Native Node-Red integration with Duet boards.
            BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
            ReleaseMgr - Duet update info inside DWC.
            Repo
            wayneosdiasundefined 1 Reply Last reply Reply Quote 0
              wayneosdias @MintyTrebor
              @MintyTrebor Thnx, so what ver do you recommend for dwc,fw,btncmd so everything jibes?
                @wayneosdias Latest stable https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.5
                Repo
                • wayneosdiasundefined wayneosdias marked this topic as a question
                • wayneosdiasundefined wayneosdias has marked this topic as solved
                  @MintyTrebor @jay_s_uk Thanks guys, FW/DWC v3.4.5 and Btncmd 0.10.15 has everything working in regards to no more DWC jog errors and Fxing btncmd 🙂
