    Error Installing Motion Plugin Through DWC
    Third-party software
    • misterjtcundefined
      misterjtc
      I am trying to install the motion plugin from github listed here: https://github.com/Duet3D/DSF-Plugins/releases/
      The latest release is for 3.4.
      I downloaded the zip file and try to install it via the install plugin button under external plugins in the DWC. Initially everything appears to be working fine and then eventually after its tried to installed for a minute I am presented with the error below.
      I am running DWC 3.4.5 via a Raspberry Pi 4.
      What am I doing wrong?
      • chrishammundefined
        chrishamm administrators @misterjtc
        @misterjtc You missed the upgrade notes, in particular about installing AppArmor: https://github.com/Duet3D/DuetSoftwareFramework/wiki/Changelog-DSF-3.x#version-330 The latest DuetPi image already comes with a preconfigured AppArmor installation.
        Duet software engineer
        misterjtcundefined 1 Reply Last reply Reply Quote 1
          misterjtc @chrishamm
          @chrishamm thanks for the reply.
          I apologize but I only have basic knowledge of this type of stuff. That changelog is pretty old and my Duet install is less than a month old. Therefore my install should already include AppArmor but I guess it doesn't?
          It's not quite clear to me but it seems like you are telling me to install and configure AppArmor per that old change log?
            misterjtc
            I can confirm that following the instructions in the changelog that you linked to install AppArmor has corrected the issue.
            Thank you @chrishamm !
            • dc42undefined dc42 marked this topic as a question
            • techworldundefined
              techworld
              This post is deleted!
