Voron 2.4r2 Duet 3 Mini 5+ EB 2+ Klicky Probe Firmware
I built a Voron 2.4r2 with the hardware listed. I need to get it running but I am not quite sure what g code I need to get the Klicky set up and calibrated and I am not sure what g code (or macros). I need to set up the macros QGL using the probe. I found a set of Rep Rap files on GitHub created by pRINTERnOODLE. However he uses a fairly complex set of macros that include a lot of variables and programming that I do not really understand. I am hoping someone has done this using more direct g code macros that I do understand. I would alos like to send I need to set up the QGL using the probe.
This is a bit off topic but related so I hope no one gets upset. I would also like to send pRINTERnOODLE a DM but I could not figure out how to do that on GitHub. If someone can help with that as well that would be appreciated.
Any and all help would be appreciated. Thanks
@JADoglio @printernoodle is their handle here, but it looks like they haven't been online for over a year. There's also @Nurgelrot who has done these configs: https://github.com/Nurgelrot/Voron-2.4r2-RRF-configs/blob/main/Macros/Calc Z offset
@droftarts Thanks. Nurgelrot's solution is simpler and more helpful. If anyone else has any other ideas please let me know.
