    Duet2 + USB Memory
    Third-party add-ons
    • Aitorundefined
      Aitor
      Good morning to all,
      I would like to know if there is any way or if you know any USB type A adapter to connect to the output "PanelDue (Label: CON_SD)".
      I am currently using this and it works fine, but I would like to be able to use a USB stick instead of an SD card.
      But I would like to use something like this
      Do you know if this would work?
      Do you know how it should be connected?
      Do you know of another similar component that works?
      Thanks in advance
      Best regards
      @AITOR
      chrishammundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @Aitor
        @Aitor No, that isn't supported, you'd have to add an SBC to get USB support. At some point we may add support for external USB drives to RRF, but it's questionable if that change will make it to the Duet 2 build.
        Duet software engineer
          dc42 administrators @Aitor
          @Aitor further to the reply from @chrishamm the microcontroller on Duet 2 doesn't support USB Host mode, so it would not be possible to support USB sticks directly.
          Aitorundefined 1 Reply Last reply Reply Quote 0
          • Aitorundefined
            Aitor @dc42
            Good morning @CHRISHAMM and @DC42
            Thanks for your replies, I'll stop looking then.
            Best regards
            Aitor
