HSS57 External Driver Controlled by 1XD Exentsion Board
I Have the following Setup:
Mainboard Duet 3 6HC - 1XD - 1XD - Mini5+I tried the 5V Dasychain Connection Between the 1XD and The HSS External Driver, but with this Setup the Steppers wont Move at all.
So i Started with the alternative connection, also here nothing happened.
I read in the Forum that it helped to remove the ENA + and - Connection, now i can move my Axis just fine.
But I Cant unlock the motors anymore.
Anybody able to help me out ?M569 P122.0 S0 R1 ;X physical drive 122.0 goes forwards
M569 P123.0 S1 R1 ;Y physical drive 123.0 goes backwards -
@Lexan said in HSS57 External Driver Controlled by 1XD Exentsion Board:
But I Cant unlock the motors anymore.Please explain - if you can't unlock the motors, how can you move them?
@dc42 i can move them via G1 Commands, when i'm going to use M84 the Panel shows that i have to rehome all axis but the motors are still under power and not able to move the acis by hand
@Lexan if you removed the ENA connections then the motors will always be energised. You need to connect the ENA wires if you want to be able to de-energise them. Depending on your motors, you may need to swap the + and - wires between the 1XD and your motor. DO NOT use a common +5V wire (5V daisy chain) if you do need to swap them.
@dc42 at the moment i use all 6 wires one by one from the 1xd to the signal port.
so i keep the rest the orientation from pull and dir + to + and - to -. just ena i change + to -.
i understand this correctly ? -
i understand this correctly ?Yes, just swap the ENA+ and ENA- connections over.
@dc42 said in HSS57 External Driver Controlled by 1XD Exentsion Board:
This was the Solution, Thank You !
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
