    Connecting Hobbyservo TowerPro SG90
    • gringoundefined
      gringo
      I have a TowerPro Miniservo connected to out9 and we configured in the doc in a macro.
      I have created two macros for testing one for a rotation to the right and one for a rotation to the left.
      M950 S1 C "out9" ; right turn
      M280 P1 S80
      M950 S1 C"!out9" ; left turn
      M280 P1 S80
      A rotation to the right works fast
      A rotation to the left works very slowly.
      What could be the reason?
      It is an analog servo. I have also tested a digital servo that only rotates clockwise.
      Do you have any idea what I need to change to make the servo turn fast in both directions?
      Thanks
      Lars
      • achrnundefined
        achrn
        You should define the servo only once (e.g. with M950 S1 C "out9") then you set it to different positions by using e.g.
        M280 P1 S1000              ; right turn
        M280 P1 S2000              ; left turn
        (but I don't know your orientation, so left and right might be reversed).
        Also, servos are all over the place in respect to timing - so you need to do quite a lot of trial-and-error to determine the appropriate range for the S parameter. Either use the range 0-543 or the range 544 and greater - one is a pseudo angle, the other is pulse-width-in-microseconds
        gringoundefined 1 Reply Last reply Reply Quote 1
        • gringoundefined
          gringo @achrn
          @achrn
          it works, thanks a lot.
          • droftartsundefined droftarts marked this topic as a question
          • droftartsundefined droftarts has marked this topic as solved
