Z probe already triggered at start of probing move
Hello guys, I am having some troubles with the z- probe. I am gonna put my code below so you guys can analyze it and give me feedback about it.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.15 on Sat Feb 11 2023 16:28:22 GMT-0500 (Eastern Standard Time); General preferences
M550 P" OYM Large 3D Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P5 R1 T2.5:2.5:5:5 S1 ; physical drive 5 goes forwards (X)
M569 P6 R1 T2.5:2.5:5:5 S1 ; physical drive 6 goes forwards (Y1)
M569 P7 R1 T2.5:2.5:5:5 S1 ; physical drive 7 goes forwards (Y2)
M569 P8 R1 T2.5:2.5:5:5 S1 ; physical drive 8 goes forwards (Z)M584 X6 Y7 Z5 ; set drive mapping
M92 X15.00 Y15.00 Z100 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z1500 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X708.9 Y694.5 Z700 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M575 P1 B57600 S1
M307 H0 R0.200 K0.572:0.000 D15.00 E1.35 S1.00 B0thank you!
What hardware? Looks like it could be Duet2 mainboard, is that so? What probe hardware?
What troubles? Presumably at least some of them are "Z probe already triggered at start of probing move", but is that all?
Is teh probe triggered before you start a homing move? What does DWC user interface show?
Post your homing files. Also post the result of sending M122 and M98 P"config.g" please.
I recently repaired the Z probe, but now I am facing a new problem. I am uncertain about how to set up my homing process because every time I reset the printer to 0,0 and turn it off and on again, the printer forgets the homing. Furthermore, when I press the homing button and the Z-axis is at the midway point, it does not move all the way up to touch the sensor and complete the homing process. This issue is also occurring with all the other axes.
Please if I didn't explain myself correctly, Let me know so I can clarify any mis understating.
Here is my Homeallg config:
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 20:39:14 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 H1 X-621 Y621 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-624 Y624 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z705 F360 ; move Z up stopping at the endstop
G90 ; absolute positioning
G92 Z700 ; set Z position to axis maximum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningHomeZ:
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 20:39:15 GMT-0500 (Eastern Standard Time)
G1 H1 Z705 F1800 ; move Z up until the endstop is triggered
;G90 ; absolute positioningHomeX:
; homex.g
; called to home the X axis
G1 H1 X-621 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-621 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioningHome Y:
; homey.g
; called to home the Y axis
G1 H1 Y621 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F6000 ; go back a few mm
G1 H1 Y621 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning -
@JlunaMX said in Z probe already triggered at start of probing move:
I recently repaired the Z probe, but now I am facing a new problem. I am uncertain about how to set up my homing process because every time I reset the printer to 0,0 and turn it off and on again, the printer forgets the homing. Furthermore, when I press the homing button and the Z-axis is at the midway point, it does not move all the way up to touch the sensor and complete the homing process. This issue is also occurring with all the other axes. Moreover, when the Z-axis goes up and I intentionally trigger the sensor with my hand to test if it stops, it doesn't do anything and keeps going up.
; homeall.g
; homez.g
; homex.g
; homey.g
This is normal. When the motors are de-energized, their position is lost, the motor coils may snap to the nearest full step in whatever direction that may be, so you must rehome.
Your homing files are not configured to use the probe at all. You need to change them to something like this.
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 20:39:14 GMT-0500 (Eastern Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-621 Y621 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-624 Y624 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X150 Y150 F6000 G30
HomeZ:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 20:39:15 GMT-0500 (Eastern Standard Time) G90 ; absolute positioning G1 X150 Y150 F6000 G30
I think that may be partly because your steps per mm is very wrong for X Y Z. How did you determine those values?
The other part is that your axis legnth is longer than you've set for the homing move.
@Phaedrux thank you just fixed my homing problem.
I am facing an issue where the X-axis continues to move even after touching the endstop, causing it to crash. As a result, I am unable to print properly. Can you suggest a solution to this problem?
To answer your question about how I determined the values for the steps per mm, I simply experimented until I was able to achieve a smoother movement of the motor. If I had left it as it was before, the belt would have slipped from the gear.
Or do you have a better way that you can recommend me to do it?
I am really a newbie on this.
Well the steps per mm is a function of your motor step angle and your belt and drive teeth. It's important to get this correct because it determines the distance a commanded move with actually move.
If it's wrong, when you tell it to move 100mm it may move more or less than that. So if you have a ruler, tell it to move 100mm and verify if it actually moves that much. It sounds like you have long axis, so even small errors can compound.
The formula for steps per mm on a belted axis is
xy_steps_per_mm = (motor_steps_per_rev ∗ driver_microstep) / (belt_pitch ∗ pulley_number_of_teeth)
Use M119 to check the status of the endstops. Send it when the endstops are triggered physically with your finger, and again when they are not. Does the reported status match?
Here is what it gave me per your request. my motor didn't even move haha, did a really weird sound and I stopped everything due to that sound.
I am not sure if I have to play with it a little but more until they move. I am going to put the microstep on 400 which is the lowest instead of 1600.
@Phaedrux Bro. I am facing now another issue. When I am printing and I put the layer height to 0.3mm. it does not goes to 0.3mm it stays at 2.5mm which is the offset that i have pre-set for the printer when I do Home.all
Any input on this one?
I have attached my settings
@JlunaMX Here my config.g in case you needed:
; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 20:39:14 GMT-0500 (Eastern Standard Time); General preferences
M550 P"O&MAKERSLAB" ; set printer name; Network
M569 P8 R1 T2.5:2.5:5:5 S1 ; physical drive 8 goes forwards (Z)M584 X6 Y7 Z5 E8 ; set drive mapping
M92 X45 Y45 Z400.00 E374.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E400.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E3000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E500.00 ; set motor currents (mA) and motor idle factor in per cent
M208 X708 Y694 Z700 S0 ; set axis maxima; Endstops
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Z-Probe
M558 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P1.5 X0 Y0 Z0.1 ; set Z probe trigger value, offset and trigger height
M557 X15:621 Y15:621 S101 ; define mesh grid; Heaters
M143 H0 S300 ; set temperature limit for heater 0 to 300C
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT1000 on pin e0temp
M307 H1 B0 S0.50 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S300 ; set temperature limit for heater 1 to 280C
M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as PT1000 on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S0.50 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S315 ; set temperature limit for heater 2 to 315C; Fans
M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 D0 H1:2 S"Typhoon" ; define tool 0
M575 P1 B57600 S1
T0 -
I think you made a mistake with the belt pitch. It's in mm. 0.2 is supposed to be 2 since that's a common belt pitch.
And driver microstep is 16, not 1600.
Are you sure the pulley tooth count is 30?
motor_steps_per_rev 200
driver_microstep 16
belt_pitch 2
pulley_tooth_count 30
XY_steps_per_mm 53.3
travel_per_step 0.01875000
travel_per_rev 3.75000000 -
How did you get G31 Z2.5? This should be the height of the nozzle above the bed when the probe triggers. You must measure it, along with the XY offset of the probe from the nozzle.
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
Additionally, how can I make babystepping work? I've noticed that when I click on it while printing, it doesn't move down to match the layer height required for correct printing.
Baby stepping won't let you go below the M208 Z minima value you've set. If you require a lot of baby stepping to get the first layer right, you've got other issues you need to solve first, likely measuring the probe offset. If Z0 is set correctly, you shouldn't need baby stepping at all.
Did you update your homing files with my suggestions?
@Phaedrux Yes I did Update the homing files and updating that my homing is correct, now everytime I press the homing button it goes where it should be.
Now going back to the step per mm. I did what you told me and this is what I got:
Does it makes sense for you? because my machine when I put the 41.995 it does more steps per mm that it should do. And yes my pulley its 30 tooth.
Besides that with my setting being like this:
with calculation:
without calculation (experimenting) in this case the x & y run 50mm when pressed to do so, meanwhile utilizing the numbers from the calculation it goes beyond 50mm:
Right now I am not sure what to do.. If changing the pulley of the motor and belt for a better combination or leave it like that. But here is the thing if I leave it as is the prints comes out weird.
For example yesterday I was printing this:
and ended up looking like this
At this point I'm not sure what the issue could be. It could either be a mistake in the steps per mm, or there might be a problem with the configuration files.
Belt pitch 5.08mm? What kind of belt do you have? If you hold a ruler with mm markings up to the tooth side, how far apart are the teeth?
@Phaedrux Yes, its 0.20in and in mm is 5.08mm
here is a picture from the manufacturer;
It's strange that the steps per mm that create accurate movement is exactly half of the calculated value. This makes me think we're missing something. If the drive pulley tooth count were actually 60 teeth that would give 21 steps per mm.
Would you be able to post some photos of the machine so I can get a better idea of what you've got?
If 21 produces the correct amount of movement, that's great though.
Is the Z axis moving correctly?
@Phaedrux Yeah I know its very strange. Yeap the z axis is moving ok so far. If anything I will keep you updated.
I will post some pic soon of the machine
@Phaedrux I've fixed the steps per mm issue. Switching to an encoder driver and applying the equation resolved the problem for the X and Y axes, now set to 42 steps/mm.
However, there's an issue with the Z-axis. The offset from the G-code isn't functioning correctly, despite being shown on the Duet interface. I suspect it's due to the Z-axis calibration, especially since I'm using a leadscrew. How can I calculate the steps/mm for the Z-axis with a leadscrew?
