    3.5beta2 looping jam
    Beta Firmware
    • Aitorundefined
      Aitor
      Good morning @dc42,
      It's possible that this has already been reported or it's my fault, but in case it wasn't, I'm mentioning it here
      I was doing some write tests with this code (simplified):
      var cont = 1
      var material = "ABS"
      echo >"fff" ";NEW"
      echo >>"fff" ""
      while var.material != "FIN"
      	if var.cont = 1
      		set var.material = "ABS"
      	if var.cont = 2
      		set var.material = "ASA"
      	if var.cont = 3
      		set var.material = "FLEX"
      	if var.cont = 4
      		set var.material = "NYLSTRONG"
      	if var.cont = 5
      		set var.material = "PET-G"
      	if var.cont = 6
      		set var.material = "PLA"
      	if var.cont = 7
      		set var.material = "PP"
      	if var.cont = 8
      		set var.material = "TPU_HARDNESS"
      	if var.cont = 9
      		set var.material = "FIN"
      	if var.material != "FIN"
      		echo >>"fff" "    <!--***-->"
      		echo >>"fff" "    <!--"^{var.material}^"-->"
      	set var.cont = var.cont+1
      	M400
      echo >>"fff" "    FINIS"
      Board: Duet 3 MB6HC (MB6HC)
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.5beta2 (2023-02-08)
      This was the error message: Error: Bad command: hile var.material != "FIN"
      Could not get out of the while, am I doing something wrong, I didn't take something into account?
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.5 (2022-11-30)
      Yes it worked, no problems
      I'll look forward to your comments
      Best regards
      Aitor
        jay_s_uk @Aitor
        @Aitor it's been fixed already and there's a new build here https://forum.duet3d.com/post/307796
        Aitorundefined 1 Reply Last reply Reply Quote 1
        • Aitorundefined
          Aitor @jay_s_uk
          Good morning,
          Thank you very much @jay_s_uk, the problem is indeed solved.
          Best regards
          • dc42undefined dc42 marked this topic as a question
