Duet 2 Wifi dropping
My duet 2 wifi is running current firmware. Today during a print my wifi not connected. Is there something I can do to reconnect without losing the current print?
@rmilyard can you connect via USB? if so, send
M552 S0
thenM552 S1
@jay_s_uk not sure have cable long enough. Is that only way to get it back?
@rmilyard do you have a display on the board?
otherwise its wait for the print to finish -
@jay_s_uk not yet. I was planning on adding one soon.
@jay_s_uk I found long enough cable. So what program would I use? SSH?
@rmilyard use putty/YAT and as a serial connection
https://docs.duet3d.com/en/User_manual/Troubleshooting/Terminal_Emulatorswould be good to grab an output of M122 before your send the above commands (you can do that over serial too)
