Z axis question
  • Hi David DC42, Hi all people
    is it possible with the Duet FW 1.20 ( plus x5 ) having 4 Z axes simultaneously with the new control loss control features, to have a self leveling?
    Thank you
    If you mean with sensorless homing, that is not recommended for the Z axis. However, you can home the Z axis using the Z probe.
    Unless the bed is large and has enough flexibility that you can adjust all 4 leadscrews sufficiently without it binding, you would be better off using 3 leadscrews, not 4.
