    probe temperature compensation
    • achrnundefined
      achrn
      https://docs.duet3d.com/User_manual/Reference/Gcodes#g31-set-or-report-current-probe-status states that T parameter is 'T' (temperature coefficient of Z parameter in mm/°C, default zero), implying a linear temperature compensation. However I notice that if I do just G31 I get a response that implies something more complex:
      g31
      Z probe 0: current reading 0, threshold 500, trigger height 0.870 at 30.0°C, temperature coefficients [-0.0/°C, 0.0/°C^2], offsets X23.0 Y5.0
      Is there any documentation of this (apparent) non-linear compensation?
      Is it only A x T + B x T^2 (where A and B are two coefficients supplied to the T parameter)?
      I have a probe that is temperature dependent (actually a Prusa PINDA V2), and it's a non-linear response, so I'm interested in this.
      • achrnundefined achrn marked this topic as a question
      • achrnundefined
        achrn
        Should have used the source....
        See https://forum.duet3d.com/topic/31631/out-of-date-g31-documentation/1 where I think I've answered this question.
        • achrnundefined achrn has marked this topic as solved
