    Heater fault on boot
    • andrefrankenundefined
      andrefranken
      I'm doing the initial setup of my printer (with duet wifi) and have an issue with both the hotend and heated bed.
      The web interface tells me there is a fault with both the hotend and heated bed. I'm not sure what is causing it to think there is a failure.
      Both thermistors appear to be working correctly, they both read around 20 degrees and respond to the heat of my finger when touched.
      Clearing the fault with M562 does not appear to do anything.
      I managed to successfully perform the temperature tuning on the hotend by changing the max temp with M143 and M303. So I know that it is capable of heating, but it still doesn't accept a setpoint.
      The heated bed failed the tuning as it did not heat up at all, I'll have to double check the wiring of the heater bed.
      Any help would be appreciated!
        What is the exact error message you are getting from the web interface, and which firmware version are you running?
        Please post your config.g file.
          andrefranken
          I'm running 1.19 as was already loaded on the board when I received it.
          The error is something along the lines of "Heater Fault, Check the console, Check the wiring and reboot" The console has no further information.
          I'm not at home at the moment, so I used the RepRap configurator to generate the config below based on the same choices I made at home. Should be the same.
          [[gcode]]
          ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
          ; generated by RepRapFirmware Configuration Tool on Fri Nov 17 2017 10:34:00 GMT+0000 (GMT)
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
          M665 R105.6 L215 B85 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
          M208 Z-0.1 S1 ; Set minimum Z
          M574 X2 Y2 Z2 S0 ; Set active low endstops
          M558 P1 X0 Y0 Z0 H10 F120 T2400 ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds
          G31 P500 X11 Y0 Z2 ; Set Z probe trigger value, offset and trigger height
          M557 R85 S20 ; Define mesh grid
          M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
          M92 X200 Y200 Z200 E873 ; Set steps per mm
          M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
          M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
          M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
          M143 H1 S250 ; Set temperature limit for heater 1 to 250C
          M563 P0 D0 H1 ; Define tool 0
          M550 PMiniKossel ; Set machine name
          M552 S1 ; Enable network
          ; Access point is configured manually via M587 by the user
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          T0 ; Select first tool
            andrefranken
            Ok I found the issue, the config had the following problematic lines
            [[gcode]]
            M143 H0 S ; Set temperature limit for heater 0 to C
            M143 H1 S ; Set temperature limit for heater 1 to C
            I put values in and it works now
            Thanks for your assistance!
