firmware update bricked my duetwifi
tried updating from 3.2 to 3.4.5, started update then just shut down i powed it up and no response from controller and now it will not connect to anything, panel due,WiFi, or USB help please
thanks -
You can recover any failed firmware update by reflashing via USB and Bossa software.
See the instructions here:
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2If you're unable to get the board to show up in Bossa after going through that, go through this guide and let us know what you find.
https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
@Phaedrux bossa does not pick up the board tried reseting board its on my desk with nothing but usb plugged in and it wont recognize it, I tried the steps in both those instructions/guide no luck
@Phaedrux the diag light is on constantly when power is applied
i got the duet to bossa port reset button did nothing shorting the pins did something and made it work again going to try and install firm ware i will report back results
@biga12 finally got the right firmware on the board ruined my sd chard somewhere along the line but its up and running thanks
@biga12 pretty sure the issue was caused because i use a fan output to control an SSR that supplies 120 power to the PSU on the machine so i can have the machine shut itself off after a print to conserve power use and adds a piece of mind i was originally going to set up so some sort of error could shut the machine down in the case or a bad thermistor or something, so when it reboot to flash the firmware it lost power and caused errors in the firmware next time ill lock power on maybe a programming switch or something, idk
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
