Uable to access DWC
I try to connect Duet Web Control. I got a webpage where connecting is always cycling...and on the bottom in red "incompatible firmware version".
I try to change it with SD card and M997. Still bugging in this situation.
Any advise.
Here the M122 OUTput:
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or laterSlowest loop: 15.43ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi signal strength -60dBm, reconnections 0, sleep mode modem
- WiFi -
What firmware version were you using before updating?
Did you also update your DWC files?
At this point I think you should probably use Bossa to flash the latest firmware directly, and then manually update the DWC files on the SD card.
Use this procedure to flash the firmware: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
Use this firmware file: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2CombinedFirmware.bin
Then update the DWC files by putting the SD card into your PC and extract the contents of this zip file into the WWW folder on the SD card: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/DuetWebControl-SD.zip
When you are all done and connected to DWC, upload this zip file to the system tab in DWC. https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
