    The printing channel... or what to do with a webcam.
    Duet Web Control
    • zBeebleundefined
      zBeeble
      So... I have a duet2wifi. Love it. I also have a number of raspberry flavoured pis. One of them has the PI camera on it. I would like to have automated time-lapse of the printer running ... partially to identify what set off the pile of spaghetti I sometimes find.
      I see there's a plugin --- motion webcam plugin --- but I'm a little on the back foot trying to figure out ... Does it do what I want? How do I install it?
      What would I like? Ideally a time-lapse stored for each print. What is minimal --- I suppose the default is just putting the camera in motion mode.
        jay_s_uk @zBeeble
        @zBeeble unless you're running the duet 2 in SBC (having removed the wifi module etc) you can't use the motion plugin.
        Have a look at duetlapse https://github.com/stuartofmt/DuetLapse3 as it should do what you want
        zBeebleundefined 2 Replies Last reply Reply Quote 0
        • zBeebleundefined
          zBeeble @jay_s_uk
          @jay_s_uk so... you're saying that the duet is mounted into an SBC --- via serial or whatever the wifi/ethernet connect to?
            jay_s_uk @zBeeble
            @zBeeble no. you either remove the ethernet module and use the headers there or remove the wifi module and then solder to the board.
            See https://forum.duet3d.com/topic/31725/duet-2-wifi-sbc and https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc/163?_=1617469843240
            The SBC then connects to the board using SPI
            • zBeebleundefined
              zBeeble @jay_s_uk
              @jay_s_uk I have to say, my mind is kinda blown on what this can do. I suppose I'm off on this rabbit hole today.
