    Solved I seem to be misunderstanding M106 / fan control
    Using Duet Controllers
    115
    • SupraGuy
      SupraGuy last edited by
      Okay, so I have 3 fans defined. (One isn't really a fan, it's a set of LED pucks.
      2 are defined with thermostatic control (Fan 1 and Fan 2) and one is defined with thermostatic control off.
      M950 F0 C"out8" Q500                         ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q500                         ; create fan 1 on pin out8 and set its frequency
      M106 P1 S0 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out4" Q500                         ; Pretend that the LED lighting is a fan...
      M106 P2 S0 H0 T30:75                         ; set fan 2 value. Thermostatic control follows the bed
      So, Fan 0 is the part cooling fan. I intend this to be turned on/off using M106 S255 or M106 S0 -- at least that's what Prusa Slicer puts in the Gcode for it.
      This does not seem to work. Sometimes the fan comes on when I power up the printer and stays on. Entering Gcode in the console does not seem to affect it, with or without the "P" parameter.
      The other 2 work on the thermostatic control, but I can't seem to get them to work manually.
      I've read through the Gcode docs several times, can't seem to figure out what I've done wrong...
      Firmware info:
      Board: Duet 3 MB6HC (MB6HC)
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.5 (2022-11-30)
      Lead screw driven printer, powered by Duet 2 Wifi
      MPCNC powered by Duet 2 Wifi
      CoreXY printer driven by Duet 3 6HC
      LowRider CNC powered by Duet 2 Wifi
        dc42 administrators @SupraGuy last edited by
        @SupraGuy I suspect that you may have incorrectly specified fan numbers in your M563 command(s). Please post the whole of your config.g file s that we can check.
        SupraGuy 1 Reply Last reply Reply Quote 1
        • SupraGuy
          SupraGuy @dc42 last edited by
          @dc42 M563? I guess I didn't touch that from the configuration tool, so I think it's defined as having fan 1 (Which is the thermostatic controlled fan that keeps the heat from coming up the throat.)
          config.g:
          ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.15 on Tue Feb 21 2023 20:05:02 GMT-0800 (Pacific Standard Time)
          G90                                          ; send absolute coordinates...
          M83                                          ; ...but relative extruder moves
          M550 P"DMG3D03"                              ; set printer name
          M669 K1                                      ; select CoreXY mode
          M552 P0.0.0.0 S1                             ; enable network and acquire dynamic address via DHCP
          M586 P0 S1                                   ; enable HTTP
          M586 P1 S0                                   ; disable FTP
          M586 P2 S0                                   ; disable Telnet
          M569 P0.0 S0                                 ; physical drive 0.0 goes backwards
          M569 P0.1 S0                                 ; physical drive 0.1 goes backwards
          M569 P0.2 S1                                 ; physical drive 0.2 goes forwards
          M569 P0.3 S1                                 ; physical drive 0.3 goes forwards
          M569 P0.4 S1                                 ; physical drive 0.4 goes forwards
          M569 P0.5 S1                                 ; physical drive 0.5 goes forwards
          M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5             ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
          M92 X100.00 Y100.00 Z100.00 E395.45          ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z3000.00 E2700.00     ; set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z1500.00 E3000.00     ; set accelerations (mm/s^2)
          M906 X1100 Y1100 Z800 E800 I30               ; set motor currents (mA) and motor idle factor in per cent
          M84 S60                                      ; Set idle timeout
          M208 X-15 Y0 Z0 S1                           ; set axis minima
          M208 X235 Y250 Z243 S0                       ; set axis maxima
          M671 X-35.3:271.3:117.5 Y34.5:34.5:307.8 S5  ; Motor positions: -35.3,34.5; 271.3,34.5; 117.5,307.8
          M574 X1 S1 P"^io0.in"                        ; configure switch-type (e.g. microswitch) endstop for low end on X via pin ^io0.in
          M574 Y1 S1 P"^io1.in"                        ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ^io1.in
          M574 Z2 S3                                   ; configure sensorless endstop for high end on Z
          M950 S0 C"io4.out"                           ; create servo pin 0 for BLTouch
          M558 P9 C"io4.in" H5 F120 T6000              ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y-36 Z3.24                       ; set Z probe trigger value, offset and trigger height
          M557 X5:205 Y2:202 S50                       ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
          M307 H0 R0.155 D15.47                        ; set PID parameters for heated bed
          M140 H0                                      ; map heated bed to heater 0
          M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
          M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
          M307 H1 R1.800 K0.448:0.000 D7.97 E1.35 S1.00 B0 V24.1
          M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
          M563 P0 S"Hemera" D0 H1 F1                   ; define tool 0
          G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
          G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
          T0                                           ; select first tool
          SupraGuy 1 Reply Last reply Reply Quote 0
          • SupraGuy
            SupraGuy @SupraGuy last edited by
            Okay, I'm re-reading the M563 page, and it seems that I should tell it that it's fan 0. I'll change that, and see how it works...
            • SupraGuy
              SupraGuy last edited by SupraGuy
              Okay... I changed the line:
              So now it reads:
              M563 P0 S"Hemera" D0 H1 F0
              And... nothing changed. Still can't seem to control the fan, it still comes on full blast when the board powers up.
              So... maybe it's the control pin? I changed it to "out9" and moved the fan connector. Yay, it's off... and won't turn on....
                Can you send these commands manually?
                M106 P0 S0 H-1
                M106 P0 S1
                Does it work?
                • SupraGuy
                  SupraGuy @Phaedrux last edited by
                  @Phaedrux that would be no.
                  So if I define fan 0 on out8, the fan comes on. If it's on out9, it is off. If I define it as thermostatic, it comes on at temperature, so pretty sure that it isn't hardware.
                  M950 F0 C"out9" Q500                         ; create fan 0 on pin out7 and set its frequency
                  M950 F3 C"out8" Q500
                  M106 P3 S0 H1 T45
                  M563 P0 D0 H1 S"Hemera"                      ; define tool 0
                  Current state of config.g with fan 0 on out9 and a fan defined on out8 with thermostatic control. I also tried changing the tool to the non zero fan to see if that was it. Grasping at straws... currently the F parameter for M563 is not defined, to let it default to 0.
                  • SupraGuy
                    Okay. I give up. I left the printer on and had a shower, when I came back, the part fan was on, and I could turn it off. So... yay?
                      Call an exorcist.
                      Is the fan failing maybe?
                      • SupraGuy
                        Doubtful. It's brand new, but with some of these Chinese parts that might not mean much. The fact that it worked reliably on thermostatic control is what really gets me though.
                        Hopefully I don't have to change the config file anymore, so if it acts up again, I'll replace the fan.
                        • Topic has been marked as a question  SupraGuy SupraGuy
                        • Topic has been marked as solved  SupraGuy SupraGuy
