    3.5b2 - Macros called from a job lose parameters.
    Beta Firmware
    583
    • pfnundefined
      pfn
      This has been working for me fine in 3.4.x, however upon migrating to 3.5b2 I am encountering a problem in calling a macro with parameters from a job and get an error like: Error: in file macro line 18 column 12: meta command: unknown parameter 'H'
      In the job, the macro is called as M98 P"job-prologue.g" T240 H110 L0.2 S0
      This command works directly from the console. In some instances, the first run of the job with macro works. It's very odd as the check for exists(param.H) passes without error.
      cube_1.gcode
      job-prologue.g:
      ;M98 R1 ; commented out, tried with and without
      if !exists(global.probe_block_detach)
        global probe_block_detach = false
      set global.probe_block_detach = false
      G21 ;metric values
      G90 ;absolute positioning
      M83 ;relative extrusion
      M107 ;start with the fan off
      G92 E0 ;zero the extruded length
      M150 K1 R255 P192 S1 F0
      if !exists(param.H)
        abort "Missing H"
      M140 S{param.H} ; start preheating the bed
      M190 S{param.H}
      if param.H >= 100
        while heat.heaters[0].avgPwm > 0.28
          echo "Waiting for bed heater to settle"
          G4 S60
      M150 K1 U255 B255 P192 S1 F0
      set global.probe_block_detach = true
      var need_g32 = false
      G10 P0 S{param.T} R50; start preheat hotend_0
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
        set var.need_g32 = true
        G28
        if result != 0
          abort "Homing failed"
      else
        G28 Z
        if result != 0
      if var.need_g32
        M402
        M98 P"k/brush-nozzle.g"
        G1 Z15 F2400
        M401
        G32
        if result != 0
          abort "QGL failed"
      if var.need_g32
        G29
      M402
      M116 P0
      M98 P"k/clean-nozzle.g"
      G1 X297 Y150 Z1 F12000
      G1      Y50 Z{param.L} E30 F500 ;intro line
      G92 E0 ;zero the extruded length again
      M150 K1 W255 P192 S1 F0
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • pfnundefined
        pfn
        Whats weird is when the heaters are turned on, these variable errors stop getting spit out.
          dc42 administrators @pfn
          @pfn I suspect this is an issue with the multiple file readers in 3.5. I will add your example to my list of issues to investigate.
          pfnundefined 1 Reply Last reply Reply Quote 0
          • dc42undefined dc42 referenced this topic
          • pfnundefined
            pfn @dc42
            @dc42 was there any change in b3 that would have helped here? I am currently avoiding b3 due to the news I've heard about extrusion issues with toolboards.
            • chrishammundefined
              chrishamm administrators @pfn
              @pfn I have identified a bug that could erase the variables from the macro scope of a second file reader if the first one caused the print to abort. I have been unable to reproduce other variable-related problems apart from this scenario, even with your G-code scripts.
              Duet software engineer
              • pfnundefined
                pfn @chrishamm
                @chrishamm I hope that's enough to fix my issue then. At the moment, this is 100% reproducible causing problems in my configuration--I have to run my start gcode separately as a macro before invoking my print job.
                But for me, this happens regardless of a previous aborted print. A slightly different scenario, but maybe it's related regardless.
                • OwenDundefined
                  OwenD @pfn
                  @pfn said in 3.5b2 - Macros called from a job lose parameters.:
                  You can't use T as a parameter in your M98.
                  It will be trying (and failing) to select tool 240 and then treating the following H110 as a new command I believe.
                  You cannot use P as a parameter (as P is already used to reference the gcode file that is being called by M98)
                  When using a macro as custom gcode, do not use G, M, N, or T as parameters in a custom 'G' gcode file. Do not use G, M, or N as parameter in a custom 'M' gcode file. There are no standard G or M commands that use these parameters and RRF will treat the parameter as being the start of the next command.
                  • pfnundefined
                    pfn @OwenD
                    @OwenD This is only true, about not being able to use T, if there is a behavior change (undocumented) from 3.4 to 3.5
                    According to your posted quotation, T is only prohibited in custom 'G' code files (e.g. G123.g), and there is no prohibition on T in custom 'M' code files (i.e. completely valid in any of M123xyz.g). Additionally, it is not prohibited from general macros.
                    But it does sound plausible that the move to multi-stream processing might have a bug around honoring these rules.
                    • OwenDundefined
                      OwenD @pfn
                      @pfn
                      You are correct.
                      I just tried it and T is allowed in M98 (and works fine).
                      • pfnundefined pfn referenced this topic
