    Duet toolboard connector loosened during print,
    • terencemuscatundefined
      terencemuscat
      Yesterday I had an ongoing print, and the CAN connector loosened and thus the toolboard was loosing and regaining connection. When I noticed this I paused the process and emergency stopped.
      I fixed the connector but now I can get no connection via CAN.
      I tried a different tool distribution board to no avail
      M122 B10/ B121 gives timeout.
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.3 (2022-10-05 09:06:36) running on Duet 3 MB6HC v1.01 (SBC mode)
      Board ID: 08DJM-9P63L-DJMSS-6J1F0-3S46P-9UFZ8
      Used output buffers: 1 of 40 (14 max)
      Static ram: 152816
      Dynamic ram: 67240 of which 24 recycled
      Never used RAM 130592, free system stack 219 words
      Tasks: SBC(resourceWait:,0.5%,454) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,334) TMC(notifyWait,7.8%,91) MAIN(running,87.9%,923) IDLE(ready,3.7%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:16:54 ago, cause: power up
      Last software reset at 2023-03-18 00:25, reason: User, GCodes spinning, available RAM 130304, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 134
      MCU temperature: min 20.3, current 33.0, max 33.5
      Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 8, reads 20547, writes 16 timeouts 0
      Driver 1: standstill, SG min 0, mspos 8, reads 20547, writes 16 timeouts 0
      Driver 2: standstill, SG min 0, mspos 16, reads 20545, writes 18 timeouts 0
      Driver 3: standstill, SG min 0, mspos 8, reads 20547, writes 16 timeouts 0
      Driver 4: standstill, SG min 0, mspos 8, reads 20548, writes 16 timeouts 0
      Driver 5: standstill, SG min 0, mspos 8, reads 20553, writes 11 timeouts 0
      Date/time: 2023-03-18 07:46:34
      Slowest loop: 1200.74ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 9026, received 0, lost 0, boc 2
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 49), ts 5073/0/0
      Tx timeouts 0,0,5071,31,0,3918 last cancelled message type 4514 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 39474/39474
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ad10
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server v3.4.3
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 19.20, max time between full transfers: 2212.3ms, max pin wait times: 2400.8ms/18.1ms
      Codes per second: 0.04
      Maximum length of RX/TX data transfers: 3507/764
      terencemuscatundefined 1 Reply Last reply Reply Quote 0
        terencemuscat @terencemuscat
        @terencemuscat P.s. - I fixed the connector by pushing it back in, no changes in wiring.
          Do you get any lights on the toolboard? Try resetting it's canbus address?
