Summary of HuanYang VFD Control by Duet3D 6HC
I've been reading many posts here and via other sources regarding VFD and Duet3D control. To summarize what I've read, most everyone uses an inexpensive PWM to 0-10V board to control the "Inexpensive" HuanYang VFD for speed control. Someone mentioned using the 5V PWM VFD support on the mainboard, but that's still PWM. The HuanYang uses 0-5 or 0-10V speed control not PWM. There's a discussion here about what more can be "built-in" to the Duet3D for CNC spindle improvements, but no clear direction or answer for my question today.
What I'm curious of is if there's a way to configure, for example, the OUT_1 pins (out1, V_FUSED) for variable volts output to send the 0-10V control that the HuanYang VFD uses? I've connected a volt meter to see if this works, but I'm not certain of the config file parameters as I always get 0V. I've tried the following, but have also read I possibly need to disable a heater.
; Tools G10 P0 x0 Y0 Z0 G10 P0 R0 S0 M563 H0 S"Spindle" M950 S0 C"out1" R24000 Q100 T0
I hope it goes without saying, this is confusing. I already have a friend who is short and snippy about what he thinks of my knowledge on the subject, so please be constructive here.
Information About My System
Custom Built CNC - Based on IndyMill
Duet3D Mainboard 6HC with Raspberry PI
Huanyang VFD HY01D511B (HY Series) -
@dainon as far as I'm aware, a 0-10v pwm to analogue converter is the only way that'll work.
Out1 etc are all just MOSFET driven pwm controllers with no variable voltage control
Note: this is how I control my VFD -
@dainon the main issue here is that high power VFDs are prone to generating ground noise, so the 0-10V feed to them should be isolated from the Duet. Many VFDs (including the one that you are using) provide a 10V output so that you can connect a potentiometer across that 10V supply and feed it to the speed input. The PWM-to-voltage converter replaces that potentiometer.
@dc42 Thanks for that information. I've had similar issues with a hydroponic Ph sensor connected to the pumping system circuit. When the pump kicked off, the sensor got out of whack and need some time to settle. I assume what you are saying is similar that? I'm a hobbyist and not an expert in electrical circuits.
Thank you all. I bought a PWM to Analog converter and will be wiring that up today. I'll mark this topic solved.
undefined dainon marked this topic as a question
undefined dainon has marked this topic as solved
