    Having some trouble connecting smart effector/z probe
    • kylesmthundefined
      kylesmth
      I've read through the wiki and double checked all of my wiring, everything looks good. I'm thinking that I probably have an issue with the configuration, if someone would be willing to double check it for me and see if everything looks ok that would be great, thanks.
      ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Sun Nov 19 2017 10:04:54 GMT-0700 (Mountain Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R105.6 L304 B85 H201.4 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P5 R0.4 F1000 T6000 ; Set Z probe type to ultrasonic, the axes for which it is used and the dive height + speeds
      G31 P600 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; Define mesh grid
      M92 X100 Y100 Z100 E663 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P1 T100000 B4138 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M587 S"Ents" P"SafetyFirst!" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
        What isn't working?
        • kylesmthundefined
          kylesmth
          The z probe remains at zero and the green LED light does not come on. Everything else seems to be working fine, just the z probe is not triggering.
            If the green LED does not flash a few seconds after power up, most likely it's an issue with the wiring of +3.3V or GND from the Z probe connector to the 8-pin connector on the effector. It could be mis-wired, or there may be a bad crimp connection.
