    Rotating magnet filament sensor's calibrated data in OM.
    Filament Monitor
    • azs123undefined
      azs123
      Hi. Im trying to use value from filament monitor in macro. By looking at the documentation for OM i can see there is a field called sensors.filamentMonitors[].calibrated.totalDistance. I cant use this value (even during printing from sd card), because sensor always return null when trying to get sensors.filamentMonitors[0].calibrated. Does this mean it cant calibrate? if so, what are possible causes? this is my filament sensor config:
      M591 D0 P3 C"20.io2.in" S1 R10:150 E3 A1 L25.24
      M591 D0 returns:
      Maybe i am missing some additionals steps when calibrating this sensor?
      • T3P3Tonyundefined
        T3P3Tony administrators @azs123
        @azs123 which version of RRF are you using?
        www.duet3d.com
        azs123undefined 1 Reply Last reply Reply Quote 0
        • azs123undefined
          azs123 @T3P3Tony
          @T3P3Tony 3.4
          • T3P3Tonyundefined
            @azs123 ahh those fields may have been added in a later version. Try 3.4.5
            www.duet3d.com
            azs123undefined 1 Reply Last reply Reply Quote 1
            • azs123undefined
              azs123 @T3P3Tony
              @T3P3Tony I guess this might be the case, i use tool board v1.1
              • T3P3Tonyundefined
                @azs123 ah yes, that will be the reason, good spot.
                www.duet3d.com
