Hidden (non-broadcast) wifi networks
  • The Duet wifi is fantastic, once I could get it to connect 😉 (Ultibots D300VS+)
    Couldn’t find anything anywhere in the wiki about the Duet not connecting to non-broadcast SSIDs. Tried many things (got really good at reinstalling the firmware, using ‘screen’ to blindly type commands, etc 😉 Only thought of the fact that my networks are hidden after about 8h of “getting to know your shiny new bit of electronics”. Once I switched the router to broadcast the SSID, it worked immediately.
    Is there a way to make it work with the SSID hidden?
    BTW, you may want to add something to the docu 😉
    Keep up the great work! The controller is absolutely mindblowing.
    See https://duet3d.com/wiki/G-code#M552:_Set_IP_address.2C_enable.2Fdisable_network_interface in particular the P parameter that is implemented in the 1.20 beta firmwares.
