    M291 S4+ commands not working on RRF 3.5beta2
    Gcode meta commands
    • SanderLPFRGundefined
      SanderLPFRG
      Hi all,
      I cannot get the M291 commands to execute well with types S4 and above. Can anyone help me figure this out? or might this be a bug?
      Software versions;
      Board: Duet 3 MB6HC (SBC mode)
      DSF Version: 3.4.5
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.5beta2 (2023-02-08)
      Expected behaviour;
      Sent via console;
      M291 S4 K{"1","2","3"} P"prompt message test"
      Response;
      Message displayed on HDMI monitor with 3 options "1", "2" and "3", which can be used as variables.
      Actual behaviour;
      Sent via console;
      Response;
      Message displayed on HDMI monitor with 1 option, "ok" (same message as S2 type message)
      Why is this happening and what can I do to fix the issue?
      • T3P3Tonyundefined
        T3P3Tony administrators @SanderLPFRG
        @SanderLPFRG said in M291 S4+ commands not working on RRF 3.5beta2:
        DSF Version: 3.4.5
        you need to keep DSF and RRF versions in sync, to do that use apt to manage your DSF and RRF versions.
        as 3.5 is still in beta you will need to switch to the unstable package feed:
        https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#switch-to-unstable-packages
        www.duet3d.com
        SanderLPFRGundefined 1 Reply Last reply Reply Quote 0
          SanderLPFRG @T3P3Tony
          @T3P3Tony Ahh ohkee! thanks for the reply.
          How do I get the files for DSF version 3.5 (beta2)? and how do I update it? same way as rrf?
          Sorry I'm newish to this stuff.
          • T3P3Tonyundefined
            @SanderLPFRG use apt to upgrade your DSF install after switching to the unstable branch. For future betas apt will upgrade DSF and RRF. Once 3.5stable is out you can switch back from the unstable to stable branch.
            www.duet3d.com
              @T3P3Tony Thanks, i understand and tried switching and updating. However, I am getting errors I do not fully understand.
              Terminal communication;
              pi@duet3:~ $ sudo rm -f /etc/apt/sources.list.d/duet3d.list
              pi@duet3:~ $ sudo bash -c "echo 'deb https://pkg.duet3d.com/ unstable armv7' > /etc/apt/sources.list.d/duet3d-unstable.list"
              pi@duet3:~ $ sudo apt update
              Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
              Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
              Ign:3 https://pkg.duet3d.com stable InRelease
              Ign:4 https://pkg.duet3d.com unstable InRelease
              Err:5 https://pkg.duet3d.com stable Release
              Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 134.209.94.168 443]
              Err:6 https://pkg.duet3d.com unstable Release
              Reading package lists... Done
              N: Ignoring file 'duet3d-stable.listsudo' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'duet3d-unstable.listsudo' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              N: Ignoring file 'duet3d-unstable.list^' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
              E: The repository 'https://pkg.duet3d.com stable Release' no longer has a Release file.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
              E: The repository 'https://pkg.duet3d.com unstable Release' does not have a Release file.
              E: Release file for http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease is not valid yet (invalid for another 28d 19h 6min 16s). Updates for this repository will not be applied.
              E: Release file for http://archive.raspberrypi.org/debian/dists/buster/InRelease is not valid yet (invalid for another 22d 3h 34min 58s). Updates for this repository will not be applied.
              What can I do?
              • chrishammundefined
                chrishamm administrators @SanderLPFRG
                You still have the stable feed configured somewhere. Run sudo rm -f /etc/apt/sources.list.d/duet3d* and ls /etc/apt/sources.list.d to ensure no more duet3d lists are present. Then send
                sudo apt update
                Also make sure that your RPi has a valid internet connection and that the datetime is set correctly (should be set automatically once an internet connection is present). If it isn't updated, see here on how to set it manually.
                Duet software engineer
                  SanderLPFRG @chrishamm
                  @chrishamm It works!!
                  It both updated correctly, and now the M291 functions correctly.
                  Massive thanks Chris and Tony.
                  I'll now work on trying to understand how I can use the input to trigger Gcode commands
                  • T3P3Tonyundefined T3P3Tony marked this topic as a question
                  • T3P3Tonyundefined T3P3Tony has marked this topic as solved
